Question about Kenmore 95012 / 95014 Electric Kitchen Range
Kenmore Range Model 95014
What is the cubic feet of this range? This model should definitely be recalled since I'm seeing the same issue with this range multiple times. The oven temp gets stuck on broil and doesn't shut-off. The range needs to be unplugged. This happened to us when the unit was 2 years old and of course it wasn't under warrantee any longer.
jessee007
  • 306 Answers
SOURCE: Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Posted on Jan 01, 2008
philbran
  • 242 Answers
SOURCE: kenmore oven and brolier will not work
The problem lies within your oven control board. This is very common and are not very hard to replace but they are expensive. You can check the price of a new control board at sears parts.
Posted on Dec 30, 2008
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SOURCE: Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
Posted on Dec 24, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a kenmore gas
Hello, welcome to FixYa.
Based on your description, I`d suggest it is the hot surface ignitor for the bake burner that is likely the problem.
Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined. It'll look like this...
** FIRST unplug the range and turn off the gas to the appliance before attempting any service...safety first**
some model ranges have in use an upper broiler the same as the lower (bake) ignitor ( some do some don't, the complete model number already does confirm this...with only the bracket perhaps being slightly different ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
Here's a helpful link...http://www.youtube.com/watch?v=cLxKoF16gac&feature=player_embedded#at=20
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
Many people overlook the ignitor, especially if it "glows" since that gives the untrained person the impression it works...that is not the case however. (Ignitor may glow but not have sufficient amperage to open valve, or open the valve slightly, even intermittently...but not hot enough to ignite the gas).
As far as checking them you don't actually need a clamp on (though it is the preferred method) you can also ohm it out to test it as follows...
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number based on the model number for the bake & broil ignitor. The number I use in most applications (it's fairly universal and replaces both long and short ignitors)... is part #12400035.
I would still double check with your model number with the part`s professional`s if you're more comfortable with that.
Hope that help`s. Let me know if I can assist you further or if anything is not clear and good luck.
Thank`s for visiting "fixya" for your repair needs. Please take a moment to rate the assistance you received here and a brief testimony is also appreciated.
Regards,
Macmarkus :)
Posted on Aug 15, 2011
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    cubic feet is the measure of volume. one cubic foot is 1x1x1 foot. the size of the microwave varies with MAKE and MODEL. but is normally in the range of 1 to 3 cubic feet
    Oct 25, 2015 | Microwave Ovens
    I AM LOOKING TO BUY A NEW REFRIGERATOR AND NEED TO KNOW THE CUBIC FEET OF KENMORE MODEL 106 59592990
    25 cubic feet
    Here is a link to the owner's manual:
    http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/user-manuals/manual-downloads/Model-10659592990/0582/0165000?modelNumber=10659592990&diagramPageId=&documentId=
    Dec 01, 2014 | Kenmore Refrigerators
    My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
    This error code has to do with the oven door lock assembly.
    What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
    Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
    I just need the specifications/dimensions of my Kenmore Elite Refrigerator, model #106.54609300. I need a new fridge of similar size to fit in an enclosed space. I have searched all over the web and...
    I have this exact model. Here are the specs:
    depth: 30"
    height: 68.5". with hinge: 69.5"
    width: 35.5"
    15.5 cubic feet in the refrigerator section
    10.0 cubic feet in the freezer section
    25.5 cu ft total
    Sep 08, 2011 | Kenmore Refrigerators
    I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
    The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
    If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
    The part number for the latch asm. which includes the switch is W10107820
    GENE
    Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
    I am getting an E0 F3 code on my oven can it be something cause by an electrical problem with my outlet the oven is a kenmore model 95014102
    All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Feb 16, 2010 | Kenmore 95012 / 95014 Electric Kitchen...
    What is the cubic feet of the JSP28 electric range oven
    I went to the GE website and submitted this question since I was looking for the same information. Allison, an Appliances Consumer Specialist, answered that the approximate size of this model oven is 3.5 cubic feet.
    Feb 21, 2009 | GE JSP26 Electric Kitchen Range
    Kenmore 95012 / 95014 Electric Kitchen Range Logo
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Mike Carew
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
