Question about Optics
How to adjust the valve - Optics
    New Friend:
    Problem Solver:
  • 5 Answers
WHAT VALVE???
Posted on Jan 27, 2013
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
08 Civic EX, valves became noisy at60K, valves quiet after warmup. They will probably still be noisy after I adjust them. Would the cause be excessive wear on the valves stem ends and rockers?
If there were no wear, the valves wouldn't need adjusting. The reason for periodically adjusting the valves is to compensate for the wear that the valve train undergoes over the life of the engine. Be optimistic! Have confidence that adjusting the valves will reduce the noisy valves.
Apr 10, 2017 | Cars & Trucks
What is the clearance between the rocker arm and the valve spring in a GM 2.2L motor
there is no specification for what you want
the valve clearance is between the end of the rocker arm and the end if the valve stem
the stem end is proud of the spring retainer so if your rocker arm is touching the spring retainer , you have a big problem as for the procedure it is set out in the workshop manual but if you don't have a manual it can be done like this
you will need the firing order of the engine first
now adjust no 1 piston valves when the next piston to fire has the valves in the rock position
that is the exhaust valve just closing as the inlet is just opening a bit of movement of the crank makes either valve move up or down
now move on to the next piston to fire and adjust the valves that were rocking
follow that procedure until all the valves are adjusted
for example
on a 4 cylinder engine with a firing order of 1--3--4--2
bring up no 1 piston and adjust the valves when the valves on no 3 piston are rocking
next piston to fire is no 4 so adjust no 2 piston valves
next piston to fire is no 2 so adjust the valves when no 1 valves are rocking
the procedure is the same for engines with any number of cylinders
Oct 19, 2016 | Cars & Trucks
When the valves are adjusted on the de-compression stroke can they be re-adjusted or is the head now faulty?
valves should always be adjusted with the cylinder being adjusted at top dead center(tdc). if you can rotate the motor by hand you can adjust the valves with no damage having being done.
Jul 29, 2014 | 1992 Toyota Pickup
Valve lash procedure
i need to know how to adjust the valves on 02 pont sunfire
Nov 20, 2011 | 1991 Chevrolet K1500
Need to find out how to adjust vavles
If your engine is an overhead valve Briggs. You need to:
Remove valve cover
Locate rocker arms. Upper is exhaust, Lower is intake.
Loosen the lock screw in the center of the adjusting nut.
With engine at TDC and both valves closed adjust both valves by turning the adjusting nut to obtain proper clearance. Once set, tighten the center lock screw.
Valve adjustment specifications vary from model to model. Would need more engine information to get you that or it can be found online.
Reinstall valve cover, make sure gasket did not get damaged.
Adjust valves on a "cold" engine.
Feb 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Overhead valves making noise like they need ajusting
Valve Lash ADJUSTMENT 1.6L Engines NOTE: Measure valve clearance with the engine cold.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the valve cover.
  3. Set the engine to Top Dead Center (TDC) of the compression stroke for the cylinder to be adjusted.
  4. Check the valve clearance. The valve clearance specifications are as follows:
    • Intake valves: 0.005-0.007 inches (0.13-0.17mm)
    • Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  5. After adjustment, tighten the locknuts to 11-14 ft. lbs. (15-19 Nm).
  6. Repeat for each valve to be adjusted.
1.8L, 2.0L and 2.5L Engines The 1.8L, 2.0L and 2.5L engines utilize automatic hydraulic lash adjusters to maintain proper valve lash at all times. Periodic valve lash inspection and adjustment is not necessary or possible. prev.gif next.gif
Sep 14, 2010 | 2000 Chevrolet Tracker
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
Apr 01, 2010 | Parks Optical Briggs And Stratton Engine...
New rebuild chatters
adjust your valves your oil pickup tube needs to be adjusted you need feeler guages to adjust the valves down properly
make sure lifters and oil pick up tubes are not clogged
feeler guage is---> thin pieces of metal cut to different sizes to hold under valve adjusters till the play and chatter gone
check by book what the feeler size needed for adjustment
Jun 07, 2008 | 1983 Chevrolet C3500
Optics Logo
19 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
