Question about Kenmore Oasis HE 27082 Top Load Washer
Coin under the kenmore elite oasis agitator, how do i remove it
I think there is a coin under the agitator, how do I remove the agitator to find out. Need help
  • 2 more comments
  • Anonymous Jan 29, 2009
    I have the same problem. It sounds like there is a coin clanking around inside when the machine changes cycles. Is it a metal object or is something very loose inside the machine? What should I do to fix this problem?
  • Anonymous Feb 14, 2009
    Wife actually watched as a coin slid under the agitator of the washer. I removed the short height agitator disc paddle and discovered that the coin(s)have dropped down into the depths of the unit via the 3-4 in X 1 inch drain slots. I haven't tried to open the back side as yet but thought you might have some insight as to how I can resolve this and whether I may be getting myself in deep? I am relatively handy with wrenches and such but absent a manuel... I guess the fundamental question is: are there zero tolerance issues with these units which will require some sort of calibration if I crack the unit open to remove the coins?
  • Anonymous Mar 17, 2014
    need to clean under agitator
  • Anonymous Mar 30, 2014
    clicking sound
  • 547 Answers
Remove cap at top of cone unscrew
Posted on Feb 12, 2009
How do I remove clothes from under agitator?
Believe it or not the agitator will come off. Look under the fabric softener cup. There should be a fastener (nut or bolt) to loosten. Give the cup a good cleaning while you have it off.
Once the nut is removed you can work the agitator off.
Jul 27, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed...
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 14, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Agitator Replacement (have parts)
See the Whirlpool Service manual for the Cabrio washer:
The Sears Oasis is basically the same machine:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have coins under the basket of my kenmore elite oasis he model 2806 how do remove the basket?
See the following Whirlpool Service Manual for their Cabrio washer. The Sears / Kenmore Oasis is basically the same machine so the procedures for pulling the basket should be the same.
Apr 26, 2010 | Kenmore 22422 Top Load Washer
How can i remove clothing stuck in my kenmore elite oasis?
if it is up under the agitator just remove the agitator,,,,pop the cap off with a screwdriver then remove the 7/16 bolt and lift out whole assy!
Feb 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,086 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
