Question about Cretors 6 oz. Goldrush Red Top Popcorn Popper
L need to order two switches for heating element, Canalta in Moosomin, Sask 306-435-3034
Canalta in Moosimin, Sask 306-435-3034
    Champion:
  • 252 Answers
Harland Fairbanks in Saskatoon should be able to help you.http://www.harlans.ca/locations.html
Posted on Feb 18, 2013
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
Why does my bosch dryer not drying my clothes
will need to check the fuse thermostats also before buying new heating element, the thermal cut off may be bad, the cycling switch, the hi-lo thermostat u can test the heating element with a multimeter for continuity etc?
Dec 18, 2014 | Bosch 500 Plus Series Nexxt Clothes Dryer...
How do i change the fuse on my Affinity dryer?
Thermistor or high limit switch has tripped; usually due to low air flow from lint build-up or vent blockage. OR, the heating element went bad and a new one can be ordered. In some cases, I have received new thermal switches with the element. It's a job getting the dryer apart and inspecting the element, but you need to know for sure before you have a fire or a control board failure.
Jun 18, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer runs but doesn't heat.
The high and Low thermostatic limit switches must be in working order for the heating element to get power to operate. High limit opens in the event of a overheat condition to cut off the heating element. The low limit cuts on and off to control normal operation of the heating element for a more or less constant heat for drying.
Mar 18, 2014 | Kenmore Elite HE4 Electric Dryer
Can't control temperature on heating element
You will need to replace the surface element switch. Here is the part to order. Below is a video to show you how to replace the switch.
Feb 18, 2013 | GE Spectra JBP78 Electric Kitchen Range
Mod # MER5710AAW The small element will not heat on its own power, but when the large front element is used, the small element heats up
chances are the infinite switch failed i would replace the switch for the small burner Part #: 7403P238-60 this should fix your problem.before ordering the part just make sure all the connections ar good on the switches after removing the back panel. hope this helps
Jun 07, 2011 | Maytag Kitchen Ranges
Need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Jan 04, 2009 | Heating & Cooling
Light does not come on, nor does it heat up
Some fryers have safety switches on the heating element, this is so they can not be turned on when not properly installed into the unit. Check to see if there are grooves or slots on the side of the fryer which correspond to grooves or slots on heating element. Then slide the heating element into the slots on the fryer.
Safety switch in most cases can not be seen and can not be disengaged by hand. The heating element must be installed properly in order to work. It may be illustrated clearly in the owners manual.
Do not try this with out oil in the Fryer!!
Nov 14, 2008 | Kitchen Appliances - Others
Cretors 6 oz. Goldrush Red Top Popcorn Popper Logo
67 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
