Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer will not print
Brand new printer, set up as shown, won't print anything
    New Friend:
  • 6 Answers
Start by printing a configuration or test page from the printer itself.
Posted on Feb 10, 2015
    Genius:
  • 1,124 Answers
If you are having problem to install the printer, or get your printer on, do the following:
Check all connections first if necesary replace the cables and try again.
Be sure the printer is ON
Go to Printers Folder (Start >> Control Panel >> Printers) And be sure your printer status is marked as "READY"
If not, Uninstall the printer and install the printer again (*A) but
During the printer installation follow the software steps
(*A)
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation.
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
Posted on Jan 28, 2009
Epson Stylus Photo R800 not printing certain color
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Aug 15, 2012 | Epson Stylus Photo R800 InkJet Printer
Lexmark Pro 915 wireless print problem
Try set a static IP on your printer. Check the steps in this article: http://bit.ly/SxORCU.
After setting a static IP, set the network port to the IP address that you provided to your printer or you can reinstall the drivers.
Jul 27, 2012 | Lexmark Pro 915 All-in-one Printer W/inks...
Brother MFC-295CN printer was stored for 2 years. Black ink won't print now no matter if brand new cartridge.
this work for me with a mfc 255cw. why it works I don't know but I will continue to use this setting. thank you
Jun 05, 2012 | Brother MFC Office Equipment & Supplies
Installed new ink on ip4200. Black will not print on test page "horizontal box", other colors print. Any suggestion on why the black won't print? Thanks.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (A), it is properly removed.
  3. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
  4. Make sure each ink tank is snapped into the printer.
Aug 26, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
Lexmark x1195 problem : No print color and black
are inks were brand new?
try reseating the inks - remove then insert it back
power cycle the printer - restart the printer
check the inks if it has clog on nozzles and contacts
check the inks position if there are ink spills
clean the heads
check the ink levels if they were low or has warning
Cannot Print from the PC
Problem
Cannot print from the PC
Solution
If you cannot print from the PC, please perform the steps below to troubleshoot the issue quickly.
1. Quickly verify that your Lexmark All-In-One or printer is not malfunctioning:
- Are there blinking LEDs?
- Is anything besides the normal readout visible on the LCD display?
- Can you make a standalone copy?
2. Open WordPad and type a few characters. Then choose Print from the File menu (do NOT click on the print icon in the toolbar). The following dialog appears:
This dialog provides the following information about the status of the printer and its settings:
* The Select Printer area contains the names of all the printers in the Printers folder.
* The name of the printer that is set as the default. (In Windows XP or 2000, you can select another printer, right-click on it, and set it as the new default.)
* If you have more that one print object for the printer (such as X8350 copy 1, copy 3, ...), these will also be shown.
* The printer status: offline, paused, etc.
You can also right-click on the printer and select Open to see if there are any print jobs in the queue that need to be purged.
Mar 27, 2011 | Lexmark X1195 All-In-One Printer
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer does not print black ink
I have seen many NEW dried out cartridges. i would try new ones again.
Dec 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing Problem
Go Applications-utilities-Print Set up utility Open Print set up utility Then Go reset Print system Then go to hp folder-device utilities-hp set up assistant Run hp set up assistant to install the drivers it will fix the Problem
Sep 05, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP LASERJET 1100 WONT PRINT
go to Start, Settings, Control panel, printers and faxes is your printer there? is there a checkmark? no, then right click and set as default, put your mouse over it does it say Ready? no, then change cable.
send test page, it should print, if not the USB or Parrallel input of your printer has a problem.
Aug 14, 2007 | HP LaserJet 1100 Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
88 people viewed this question
old marine
old marine
