Computer will not maintain connection to wireless internet
    Scholar:
  • 124 Answers
Did you check the strength of the connection?
Posted on Jan 28, 2009
Maintain wireless connection at school, is ok everywhere else...
There are some points to consider: 1. It could be that your computer is restricted from the school's wireless access point. 2. It could also be that the wireless adapter is old and might be needing an upgrade. 3. You could also try to re-type the school's wireless password in your computer is there is any.
May 21, 2013 | Toshiba (PA3212U) Wireless Adapter
I try to plug in my router so i could have wireless internet in my house and it worked. however i tried to change the name of the network because it was "default" and I did change it but i messed...
First, reset your router on the back by inserting a paperclip into the reset button. Then allow your router to reset. Also you may want to reset your modem to get it all on the same page. Next connect the modem and router. Go through the process of changing the network name again, but make sure you use a Wired computer to the router. If you use a wireless connection you will not maintain the connection when you make the change.
When the change has been made, reconnect all wireless devices. You may need to unplug both your modem and router after making the change to get them to communicate properly again.
Mar 06, 2011 | D-Link AirPlus DI-524 Wireless Router
The wireless connection in my Toshiba 1400-S151 won't maintain a connection. It disconnects every few minutes for a few seconds then reconnects. The signal strength to the router says very good to...
This could just be the setting in Device Manager under that adapter's Properties then Power Management. Untick the option "Allow the computer to turn this device off to save power", click Apply and OK your way out.
Jul 01, 2017 | Toshiba Satellite 1400-S151 Notebook
My Model number is F7D2301 and Its says I'm connected to the wireless but I cannot access the internet. Any suggestions??
Uninstall the belkin Router Monitor Software
its very important to maintain a stable connection
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 23, 2010 | Belkin (F5D72304F5D7000) Router
Able to detect other wireless networks (eg Neighbor's), but unable to detect wireless router's signal. Wireless signal, however, is detected by other computers, and therefore is transmitting.
Uninstall The Belkin Router manager Software
This is important to maintain a stable connection
Sep 22, 2010 | Belkin Basic Wireless Router
I cannot maintain a wireless connection.
this could be attributed by many factors, like interference. try changing wireless channels on your router. this might do the job.
Feb 14, 2010 | Linksys Wireless-G WRT54G Router
My wireless network on 2 computers falls away
What's happening is that one of your computers is online and when the other computer is used to go online at the same time, it takes the internet connection away from the first computer.... this is a common problem.
Here is the solution.
1. Turn off all computers, router and modem and anything else on your network (printers, etc).
2. With an ethernet cable connected between the router and modem, TURN ON ONLY THE ROUTER and let it cycle up.
3. Turn on your MODEM and let it cycle up. If you do this procedure in this order, your modem will "find" your router first and your router can then assign addresses to all computers while maintaining the proper connection to the internet...
You should now be able to share internet without the drop out.
Keep a copy of this just in case your power goes out and you need to reset.
Dec 11, 2009 | Compex NetPassage 26G / iWavePort WLU54G...
I cant get my ps3 to work with my wireless broadband
Settings > Network Settings > Internet Connection Settings (wireless connection)
Internet Connection Settings (wireless connection) This setting is available only on PS3™ systems that are equipped with the wireless LAN feature.
Set the method for connecting the system to the Internet. Internet connection settings vary depending on the network environment and the devices in use. The following procedure describes a typical setup when connecting to the Internet wirelessly.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Confirm that an Ethernet cable is not connected to the PS3™ system.
3.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings) in the home menu.
4.
Select [Internet Connection Settings].
Select [Yes] when a confirmation screen is displayed stating that you will be disconnected from the Internet.
5.
Select [Easy].
connectwired002.jpg 6.
Select [Wireless].
connectwireless001.jpg 7.
Select [Scan].
A list of access points within the range of the PS3™ system is displayed.
Depending on the model of PS3™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
connectwireless002.jpg 8.
Select the access point that you want to use.
An "SSID" is an identification name assigned to an access point. If you do not know which SSID you should use or if an SSID is not displayed, contact the person who set up or maintains the access point for assistance.
connectwireless003.jpg 9.
Check the SSID for the access point.
10.
Select the security settings that you want to use.
The types of security settings vary depending on the access point. Contact the person who set up or maintains the access point for information on which setting to select.
connectwireless004.jpg 11.
Enter the encryption key.
The encryption key is displayed as a series of [*]. If you do not know the encryption key, contact the person who set up or maintains the access point for assistance.
connectwireless005.jpg When you have finished entering the encryption key and have confirmed the network configuration, a list of settings will be displayed.
Depending on the network environment, additional settings for PPPoE, proxy server or IP address may be required. For details on these settings, refer to the information from your Internet service provider or the instructions supplied with the network device.
12.
Save your settings.
13.
Test the connection.
If you select [Test Connection], the system will attempt to connect to the Internet.
14.
Confirm the connection test results.
If a successful connection has been made, information on the network will be displayed.
Hints
  • If the connection fails, follow the on-screen instructions to check your settings. Also refer to the information from your Internet service provider and the instructions supplied with the network device in use.
  • If you test the connection immediately after selecting [Automatic] > [AOSS™] in step 7, the router settings may not be completed and the connection may fail. Wait approximately 1 or 2 minutes before testing the connection.
Mar 12, 2008 | Computers & Internet
Eee pc
when you say will not maintain wireless connection, do you mean looses the network or the acsses point? did both of your problem start at the same time? is your adapter external? what freezes? computer or internet?
Jan 02, 2008 | Computers & Internet
No conection to the internet
This is not a solution it is a request for information please do not rate this (yet anyway). The answers provided below may generate more questions. If you want me to help we are a team attempting to solve this issue. You are the hands and eyes of this team and only what you communicate here and do based on instructions will assist me in applying that information to an acceptable solution for you.
To connect a router to the internet you must configure it according to your internet security providers (ISPs) requirements where they permit such connections.
Can you provide a link to your ISP's support or help website?
If not can you provide the name of your ISP and the geographic area your service is located in (such as city and state assuming as your profile indicates you are in the US)?
Can you confirm your router's manufacturer and model as Linksys WRT54GS?
Can you look on the bottom probably on a label and find a Version number for your router and report it here?
Do you have a computer with a wired ethernet connection to test the internet connection before attempting to utilize the wireless capabilities of your router? Are you willing to do so to provide feedback to me as to the success of the router's internet configuration?
Please indicate if you you want to discuss securing the wireless connection? (This may be a wise decision if you do not want your neighbors using your internet connection and/or accessing your computers publicly shared folders, if you have any -- this is especially important if you do not intend to use the wireless capabilities for all the previous reasons.)
To do this you will need to provide the manufacturer and model
of each the Wireless Adapter or the computer with a built-in
wireless adapter you want to connect to your network?
Upon receiving that information we can discuss the options to secure the wireless connections to your system. These will allow you to make decisions on options as to what you are willing to do and maintain to secure your internet connection.
Dec 14, 2007 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
David Payne
David Payne
