Question about Zebra Z6M Plus Thermal Label Printer
Error message ribbon in on zebra 110xi4 - Zebra Z6M Plus Thermal Label Printer
  • 35 Answers
SOURCE: Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
Posted on May 12, 2008
bistek
  • 19 Answers
SOURCE: Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
Posted on Dec 01, 2008
  • 4 Answers
SOURCE: keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Posted on Mar 08, 2010
  • 4 Answers
SOURCE: broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
ozztech
  • 285 Answers
SOURCE: Zebra P330i out of ribbon
Send a command "!SA" The printes go recalibrate it self, don't forguet to put a card on the feeder.
Posted on Nov 12, 2010
Why display printer head too hot.
https://www.zebra.com/us/en/support-downloads.html
www.zebra.com/...zebra/...zebra/contact-tech-support..
Jul 03, 2014 | Zebra 110Xi4 RFID Label Printer Transfer...
Why display error printer head too hot
According to the user manual, when this error occurs, The printer stops; the ERROR light flashes.
Caution •
The printhead may be hot enough to cause severe
burns. Allow the printhead to cool.
The printhead is over temperature. Allow the printer to cool. Printing
automatically resumes when the
printhead elements cool to an
acceptable operating temperature.
Zebra 110xi4 labels jam going into the cutter
This is usually related to the setup of the printer. Check that there is no backfeed set up, and that the settings are on for calibration on head close.
Oct 10, 2012 | Zebra 110Xi4 203DPI 10100 CUTTER W TRAY...
Zebra P330i out of ribbon error message but there is still plenty of ribbon
Oct 26, 2010 | Zebra P330i Thermal Card Printer
Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Keep getting broken ribbon message on zebra P330i printer
Oct 15, 2009 | Zebra Eltron P330i Card Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Jul 27, 2008 | Zebra Z6M Plus Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra Z6M Plus Thermal Label Printer Logo
658 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
