Question about Kitchen Appliances - Others
My seal is broken
We moved and the breadmaker lid got damaged and it is not sealing flush
    Genius:
  • 1,280 Answers
Need to know the make and model# so I know who to refer you to.
Posted on Jan 23, 2013
2 Suggested Answers
SOURCE: Panasonic SD253 breadmaker, worn seal
simplybearings.co.uk
They are cheapish but you need to measure it accurately.
My Breville seems to be 10x10x19mm they are about
Posted on Sep 10, 2010
Olympia toilet fitted six months ago leaks when flushed
Then the wax seal was put on wrong. If the toilet rocks it will ruin the seal. once the wax is squeezed it can't be moved. Sometimes the wrong thickness of wax was chosen. If a new floor was put down the flange may have required a booster kit before putting the seal on
Nov 12, 2013 | VitrA Aria Toilet with Elongated Bowl/...
F1 flashing on both doors on my Fisher&Paykel dishwasher. Just turned on by themselves.. was not running either top or bottom at the time.
F1 - on dish drawers means there is a H2O leak on the machine which has activated the flood sensors.. Causes
Lid not closing.
??¢ Overfilling.
??¢ Foaming.
??¢ Not draining.
??¢ Lid seal damaged.
??¢ Dispenser or water softener or their seals leaking.
??¢ Damaged water inlet or drain hoses.
??¢ Leaking heater plate or motor seals, or drain o-ring seals.
??¢ Yoke jammed or broken.
??¢ Inlet hose to inlet valve connection loose.
??¢ Inlet valve body leak.
??¢ Heater plate damage (chipped enamel).
??¢ Dry F1 - PCB mains filter, harness or connectors, electronic controller
May 09, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
The paddle on my panasonic breadmaker has stopped turning. Without the pan the mechanism revolves but once the pan is in place the paddle does not move.
If you take the pan out of the machine and can't turn the paddle freely by hand, then the sealed bearing is frozen. You can try putting warm water in the pan and soaking it. After a few tries if it does not free up then the sealed bearing is broken and bread pan needs to be replaced. Good Luck..Hank
Feb 06, 2010 | Panasonic SD-YD205 Bread Maker
The machine does not rotate, I mean it does not mix the dough, the sound is on of rotating but it doesnt move on.
Take the bread pan and paddle out of the machine and see it you can spin the paddle freely by hand. If no, then the sealed bearing is frozen or broken. If yes keep the pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is spinning. If no then the belt fell off or snapped, or the motor is broken. Haank
Jan 04, 2010 | Black & Decker B2300 Bread Machine
F1 fault code flashing
Damage to the fill or drain hoses
Seals/O Rings (pinched, contaminated or poor join)
Dispenser (seal, diverter valve or weld leak)
Lid area (lid motors not functioning correctly, lid off
yoke or foreign object interfering with lid seal)
Dec 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
My breadmaker does not mix the ingredients when it is turned on.
1) Take the bread pan out of the machine and put the paddle in it. See if you can spin the paddle by hand. If you can...good. If you can't then the sealed bearing is frozen or broken. Try filling the pan with warm water and let it soak. If after a few times if you still can't move the paddle then the sealed bearing is broken requiring a new pan. 2) Keep the pan out and start a kneading cycle. Look trough the window on the lid. If the motor shaft does not turn then the belt fell off or has snapped. Good Luck..Hank
Dec 06, 2009 | Welbilt ABM3500 Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
The draw does not move smoothly It feels like it is binding. It could be off track or the top could be out of position causing the tight fit.
The track is mono rail and solid to carry the weigh of the tube. If it is off the track then the Tube won't fit inside the housing when moving. I think the lid seal from the top lid touching the top opening of the tube.
1-Check out the lid seal.
2- There is a possibility that the actuate valves went bad. Their functions are to hold down the lid to seal water fromgetting out of the tube during washing, and lift the lid seal up when a cycle is done. If the valves are stuck, the lid seal didn't get released to the upper position causing the friction when the tube moves in and out.
Aug 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Bread maker lid has crack in plastic
I would try www.esalton.com They are the manufacturers and you should be able to call their customer service number for parts. Good Luck!
Bekkah
Bread-maker.net
Nov 07, 2007 | Breadman TR850 Plus Bread Maker
Kitchen Appliances - Others Logo
14 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
