Question about Uniden BC248CLT Base Scanner
Acts like squelch is stuck
Uniden bc248clt acts like squelch is stuck, wont scan. when i push scan it goes to channel 21 and stays there
I had the same problem. Your board may be fried. I had to buy a new unit.
Posted on Jan 28, 2009
Squelch sound unit wont scan sound wont go away
I need to look at mine it could be a stuck monitor button or a q or chip failed . will get back with you. JR
Aug 10, 2016 | Uniden Bc340crs Bearcat 100 Channel Police...
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    I can not get my scanner to scan I have unlocked all channels turned the squelch down. It just makes a constant noise can you help
    It may because you have a birddie Frequencie in your scanner try programming another frequencie into it..
    Jun 23, 2011 | Uniden BC248CLT Base Scanner
    I cannot get the squelch to work and the scanner will not scan the channels
    hi the solution to your problem is your scanner will not scan frequencies while the squelch is open you will need to open it and ajust VR1 VR2 please check these use a plastic screwdriver when ajusting be carefull not to damage any of the components goodluck
    Jan 24, 2011 | Uniden BC248CLT Base Scanner
    I got a police scanner the squelch stays on all the time wont scan how do I fix that
    Try turning the squelch real slowly, most of the time its counter clockwise until it goes silent, hope this was helpful.
    May 31, 2010 | Uniden BC248CLT Base Scanner
    I don't have the manual for my Uniden Bearcat BC 855 scanner.
    You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
    For a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
    Dec 30, 2009 | Uniden BC248CLT Base Scanner
    Model BC248CLT. Unit locks on each channel with static noise as if squelch was misadjusted. Manual channel change and adjusting squelch does not eliminate the problem. Thanks
    Not sure about your particular model but many modern scanners have a "wait" function that can be used during a scan. Actual details vary from model and manufacturer.
    I do believe you are seeing that behavior. Quite often this can happen regardless os a manual squelch setting.
    If for instance it was set to scan for a low signal level AND (pause or stop) at that channel then no matter what you turn the squelch to it will do what it was told from another menu.
    You should check the advanced scanning section of your manual for any similar functions.
    If you are using software to run the scanner this too may have a similar setting so check there too.
    If this information was useful please click below
    Aug 18, 2009 | Uniden Office Equipment & Supplies
    Unable to quit the squelch
    This is an internal problem that can only be repaired by a technician familiar with Bearcat scanners. If you live near NJ, call 973-831-5900.
    Dec 24, 2008 | Uniden BC248CLT Base Scanner
    Scanner wont scan
    provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
    Oct 02, 2008 | Uniden BC278CLT Base Scanner
    Police scanner
    Uniden wont admit it but it has installed faulty squelch on the 248's I had the same issue. Wont sell parts either. 60 bucks to fix.
    Jul 05, 2008 | Uniden BC248CLT Base Scanner
    Uniden BC248CLT Base Scanner Logo
    562 people viewed this question
    Top Uniden Radio Communications Experts
    Jason
    John
    John
    AnyMHz.com
    AnyMHz.com
    Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
