Question about Toshiba 19LV505 DVD Player
Toshiba 19lv505 pc monitor display issue
I connected the 19lv505 to my 4-year old HP Pavilion desktop w/Win-XP and set the display to 1024 x 786 @ 60hz. I get these lines that shoot thru the display. Could it be a refresh problem?
My desktop says the device is a "monitor" but not a Plug-N-Play device as was my old 19" CRT.
Not enough info in the user guide on how to setup as a pc monitor.
Could my video card or video drivers be to old to support this type of LCD monitor?
Since Toshiba 19LV505 is a 720i monitor. Mak sure the resoltion in your PC is as one of the following:
Monitor Display modes
MODE Resolution Refresh rate
VGA 640x480 60Hz
VGA 720x400 70Hz
SVGA 800x600 60Hz
XGA 1024x768 60Hz
WXGA 1280x768 60Hz
WXGA 1280x720 60Hz
Make sure the 2nd one is no bigger than 720, (remember, it is 720i TV) Otherwise 19LV505 will not be able to handle it, all you see is black.
Try it and see if it works.
Posted on Feb 03, 2010
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft:
and here:
and here:
on May 21, 2010 | Computers & Internet
Display on hp pavilion a1600n disappears
nuked this comment
and the Fixya dates are wrong,
must be those Grimlins, do inside?
the year stamp is wrong.
Oct 26, 2017 | HP Pavilion a1600n (882780776265) PC...
My LCD not working at all
rocaafella 7, I want you to visit a very old blog on the net to see if you think problem is same as your monitor. Try connecting 1907 to a "known good" pc with win-desktop being displayed. Is monitor screen still black or blank n black? Reply back with more info. 12fixlouie
Oct 13, 2010 | HP w1907 LCD Monitor
Configuration error on windows xp code purple
if its a code purple error on ur hp computer and its a blue screen error message then the issue is with the motherboard of your computer...and in this case nothing can be done.If your computer is only 4 to 5 years old or less than that call to HP they will replace your free of cost,HP's phone number is 18004746836
Nov 28, 2009 | HP Pavilion m7560n PC Desktop
Connect tv to computer
Be sure to enable the second screen through the windows display settings. Right click on the desktop background and select personalize (VIsta) or Properties (XP). Click on the settings menu (lower down on Vista, a tab on the right for XP) and look at the monitor setup. After you are connected via cable to the TV, go there, click on the second screen and select "enable this monitor", "extend desktop onto this monitor" or something of the like. Oftentimes it will not do it if you are not already physically plugged in so ensure that you do that first.
Aug 26, 2009 | HP Pavilion Elite M9150F Desktop PC
I have a 3 year old hp pavilion dv9000. For 3
Quite often this is caused by someone changing the display type. There should be a function key control that allows you to view just your lcd display, an external display, or both. Try and change that setting and see if it will resolve your issue.
Jul 20, 2009 | HP Pavilion dv9000z Notebook
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Toshiba 19LV505 DVD Player Logo
1,541 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
