Question about Sony BRAVIA W-Series KDL-52W5100 52-Inch 1080p 120Hz LCD HDTV
I have a Sony Bravia KDL52W5100. When I turn on the tv sometimes everything is fine but other times there is no pic only rainbow stripes. I have to turn off and on the tv several times or unplug the tv to get a picture. I have tried rebooting the entire system it worked fine for couple of hours then the problem came back. Sometimes while I am watching a show the screen will gradually change into the rainbow stripe. Do I need to replace my screen and is it worth it?
  • lolacat1011
    lolacat1011 Jan 30, 2013
    I am not very tech savvy. Do I have to take my flat screen down from the wall mount and take the back panel off to do this?
  • The Knight
    The Knight Jan 30, 2013
    Without taking out from the wall mount brackets, how will to open it and check it?
    Top Expert:
  • Sony Master
  • 74,459 Answers
Check all the flat cable connections from T'Con board to panel, for loose connections. Re-seat them all.
Posted on Jan 24, 2013
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
lebones337
  • 152 Answers
SOURCE: We were watching tv on
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
Posted on Jan 01, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
  • 73 Answers
SOURCE: horizontal rainbow stripes
You need a QM board.Part#A1147800A
Posted on Nov 10, 2009
What causes colored stripes when playing commercial DVDs
Check your cables first to see if they are causing it. Faulty cables can cause all sorts of problems. If that doesn't solve it it could either be that the colour settings are wrong, for example NTSC instead of PAL or vice versa. Sometimes it is something to do with copy protection. In some cases counterfeit discs, or faulty discs. And in some cases a fault on the DVD player.
Oct 04, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Why does my lcd tv get stripes on it?
You are about to buy a new TV soon.
Lines have nothing to do with whether you watch XBOX or TV.
Oct 01, 2012 | Televison & Video
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Sony BRAVIA W-Series KDL-52W5100 52-Inch 1080p 120Hz LCD HDTV Logo
207 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
