Question about Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz Intel Core 2 Duo 4 GB DDR3 320 GB SATA HD SuperDrive Notebook
How i can visualized hidden file taken from other computer
Hidden files
Within "File Explorer", change the "View" to "Show Hidden Files".
Then, once visible, they can be deleted.
Oct 15, 2013 | Imation Computers & Internet
Tip
Geekman, Yes I have gone through the deletion of temp files and I also did a...
HARD DISK MAINTENANCE
To remove redundant and temporary files, recover hard disk space and speed up hard disk access, then hard disk maintenance should be done at least once a month.
Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too.
Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter – click to highlight the C drive and click Analyse (can skip this) - then click Defragment.
When this is completed repeat these steps for the D Drive if you have a D drive.
Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
DO NOT STOP THESE PROCESSES, LET THE COMPUTER COMPLETE THESE TASKS.
Next time when you run Disk Cleanup and Defrag to won't take as long.
on Jun 12, 2010 | Computers & Internet
Tip
Show Hidden Files and Folders_2
Contd. from Show hidden Files and Folders_1.
2 Registry Editor
Go to registry editor by running regedit in the run box {type in "regedit" in the run box}.When the
Registry Editor is opened go to “HKEY_CURRENT_USER” in the drop down snap-ins (n the left pane) Click “Software” then “Microsoft” –> “Windows”->”CurrentVersion” ->”Explorer” and
then “Advanced”. On the right pane area, double-click hidden and when the dialog box pops up, change the value to 1,then OK.
Check if it has taken effect or not and don’t forget to type
“gpupdate” in the run box to update the current changes in the system registry. You can refer to the graphical illustration below:
Still you can’t see the hidden folder? Then you need totry the Next Trick..
3. Command Prompt
Here you’ll need to do using Command Prompt (CMD), in the run box type CMD, and then select your directory where your hidden folder/file is located.
Let’s consider D: is your directory and Folder1 is the folder you had hidden.
Run – CMD (press enter) – cd (press enter) – d: (pressenter) – attrib –h Folder1 (press enter) and check if the changes has taken affect.
If you need to do unhide a file not a folder suppose a file name “Name” type like this “attrib –h Name” (the Name represents a folder name or a file name) inside the directory or the folder directory.
If you want to unhide all files or folders inside a folder/directory then type like this attrib –h *.* (press enter)
Please note that if your system is infected by virus/worm/Trojan horse, etc.. etc. then this will not work. It’s a best bet to run a virus scan, you can try with this multi-scanner from the link below : http://www.technize.com/?dl_id=6
Good luck…
If anyone knows more about the hidden file and folder (tips or tricks, not hacking), please don't hesitate to add them as comments.
on May 02, 2010 | Computers & Internet
Missing memory
There could be several reason such as extra partitions etc.
Hard drive manufacturers manufacturers calculate space in the following manor. 1000KB = 1MB, 1000MB = 1GB. A 500GB hard drive has thus 500GB storage based of the above calculation.
The software calculate space differently, 1024KB = 1MB, 1024MB = 1GB.
The 500GB is calculated as follow: 500,000,000,000 / (1024*1024*1024) = 465.66 GB
Nov 03, 2017 | MicroNet Technology Fantom Computers &...
Hi, I am able to view the pictures taken with my canon powershot s3is cam but when i connect my cam to the system none of the images shows up. But I am ablet see the pictures using the LCD display on the...
Welcome to Fixya
Sounds like the pictures are hidden. Take out the memory card of the acmera and plug it in to a computer that has a card reader. Click the file and folder options of your computer then click the box that says SHOW HIDDEN FILES AND FOLDERS. You should be able to view your pictures now using the computer.
Thank you for using Fixya!
May 31, 2011 | Canon PowerShot S3 IS Digital Camera
Help my acer aspire one got corrupted and I cannot see my files after it was fix, the guy said it was on my hidden files, how can i see them? it keeps saying acces denied. please help me, thanks
to show hidden files on your computer follow these step
if you use windows xp
1. open my computer
2. find tools and click folder option
3. on the advance setting find the category of hidden files and folder
4. show choose hidden files and folder
5. click ok
if you use windows 7 or vista
1. open my computer
2. click organize
3. click folder and search option
4. click view
5. click show hidden files, folder and drive
6. click ok
hope it helps you
May 17, 2011 | Acer Aspire One PC Notebook
How can i view hidden files in windows xp?
Kindly follow the following steps to view your hidden files in your PC...
1. Double click & Open the 'Windows Explorer / My Computer'
2. From the file menu bar select 'Tools'
3. Select 'Folder Options'
4. Select the 'View' Tab on the Option Window
5. In that tab you will find 'Hidden Files & Folders' with a folder icon
6. Select the 'Show Hidden Files and Folders' by selecting the radio button.
7. Then select 'Apply'
Now you will be able to view the hidden files & folders in your system. I have enclosed the screen shots for your better reference.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
How to resolve the hiden windows
to unhide file extensions to see what you have in XP open my computer (or windows explorer) Tools/Folder Options/View ...change 'Do not show hidden files and folders' to 'Show hidden files and folders' uncheck 'Hide extensions for known file types' if you wish you can uncheck 'Hide protected operating system files'
to unhide file extensions to see what you have in Vista open my computer (or windows explorer) Organize/Folder And Search Options/View ...change 'Do not show hidden files and folders' to 'Show hidden files and folders' uncheck 'Hide extensions for known file types' if you wish you can uncheck 'Hide protected operating system files'
if this is what you mean
Nov 07, 2009 | Cars & Trucks
Memory card password recovery
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 16, 2009 | Nokia 6233 Cellular Phone
Uploading video to computer from Kodak MX1063
Check the format of your video file, it may be hidden if it has different file extension for which your computer does not have the application to view.
Regarding your files got deleted, you might selected the option to move the files from your camera to your computer instead of copy the files.
Hope this helps.
Jul 12, 2009 | Kodak EASYSHARE M1063 Digital Camera
Apple MACBOOK PRO 13 INCH NOTEBOOK 24 GHz Intel Core 2 Duo 4 GB DDR3 320 GB SATA HD SuperDrive Notebook Logo
22 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
