Question about Ematic 7" Tablet Computer
Can not connect to internet
Keep saying need IP address
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
4.1 jellybean keeps searching for IP address. Will not connect. All apple products connect fine
This is the result of a bug in Android 4.1, you'll have to manually assign an IP address to your Android device.
Instructions on how to do this are available here:
http://www.trickswindows.com/2011/12/fix-obtaining-ip-address-android-wifi.html
Dec 15, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Hisense Codes
Try opening internet explorer and going to www.google.com
If this also produces an error, go to START -> Type "CMD" in the search box and hit ENTER
A black box will apear.
Type "ping www.google.com"
If it comes back with errors, it is your internet connection. You can be connected to your home network whilst your internet is not working.
Are you on windows 7?
If so try this:
There should be a network icon at the bottom right of your screen, a computer icon. Right click it, select "open network and sharing center"
You should have a network that says LOCAL AREA CONNECTION. Select this.
Click on DETAILS...
You should have an IPv4 Address that looks similar to "192.168.1.3"
Write down this address.
Close the current screen. You should be on the LOCAL AREA CONNECTION STATUS screen again.
Click PROPERTIES.
Double click the INTERNET PROCOTOL VERSION 4
Select USE THE FOLLOWING IP ADDRESS:
Now remember that IPv4 address i told you to remember? Well put that down in the IPADDRESS field, except add +15 to the number.
Eg. original: 192.168.1.3
Make it: 192.168.1.45
Subnet should be: 255.255.255.0
Default gateway should be the same as your IP but with a 1 at the end.
EG: 192.168.1.1
As for the DNS - Log in to your router/modem and in the summary or overview section it should list the primary and secondary DNS ip addresses, find them and fill in the remaining 2 boxes.
That's it, you're done. Enjoy your internet.
Oct 24, 2013 | Tablets & eReaders
How to view wifi address on msi tablet
How can I connect to Internet on my MSI Tablet, it keeps saying "Obtaining IP Address"??????? PLEASE HELP!!!!
Jan 19, 2013 | MSI 10 Nvida Tegra 2 Cortex-A9 Android 2.2...
I have polaroid internet tablet & it connects to the internet but its not responding
Check and make sure it's getting a IP address. Make sure you have right default router address and that u r using DHCP or PPOE.
Make sure wireless is turned on in router.
Dec 28, 2012 | Polaroid Tablet Computer PMID701
Cannot connect to the internet with my w-fi, I have put in the appropriate passwords etc to no avail, it keeps scanning for IP address. kaleidoscope639
Is there a DHCP server running? Like a router with DHCP enabled? How does your laptop connect? do you have a fixed IP address for the computers/laptops? What kind of encription are you using ? WPA ? WEP ? none ? Set a fixed IP within the same range and try again.
Mar 05, 2011 | Samsung Galaxy Tab Tablet PC
I cannot connect to the internet. My wireless connection says that it is connected to my wireless hub. All other computers in the house hold are connecting to the internet wireless, so it is not a wireless...
Do you have anti-virus installed? You may have a virus that prevents you from surfing the net.
Also check if you are getting an IP address. Go to start>run>type in cmd and press enter. On the command prompt(black screen) enter in ipconfig and see if you have a IP address
Jun 03, 2010 | Toshiba Portege M200 Tablet PC
Ematic 7" Tablet Computer Logo
49 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
