Question about Gateway Notebook PC (MX6710) PC Notebook
Dvd burner/ cd rom drive not working
At first it would open randomly when it wanted to. Then occasionally it wouldnt open if there was a dvd or cd inside and now I have tried everything and it doesnt open. I went into hardware devices and it says its connected and there are no issues but it wont open.....
on a seperate note, I've had an issue for awhile where if I was watching a dvd, if the AC adapter was hooked up to the computer, the dvd would work fine but as soon as I went to the battery, the dvd would skip. anyone have any solutions?
    Master:
  • 461 Answers
Sounds like a failed optical drive as it was requiring more power to operate normal. Will it even open if you try the software method (right-click on the drive in My Computer and select Eject)? You could also try manually ejecting the tray if there is a manual eject hole you can insert a straightened paperclip into. You will most likely need to replace the optical drive.
Posted on Jan 28, 2009
I want to open a program on a cd but when i double click to open the cd, it wouldnt open but ejects
This may be due to couple of reasons the error in the registries may also cause this issue. The first thing that you can do is to right click on the icon and then choose to explore rather than double clicking it see if that works.
Sep 23, 2013 | Hi-Val CD-ROM Kit (H4802A-15R) Burner
Works not
make sure that the cd-rw/dvd-rom burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 09, 2011 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
My drivers for cd-rom does not work
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 16, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
Sony DVD ROM will not open, light comes on and tries to open but will not. Other DVD works fine. What with the Sony DVD?
try to find a tiny hole on the drive( near LED or eject button) and insert a niddle or some kind of hard pin which can go inside of it push little bit hard (drive will open) , dont keep your drive empty if not in use put any useless DVD ROM in it so that it will get open when you want to use
Apr 24, 2010 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
My Toshiba M45-s359 dvd/cd burner does not work
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
thankyou
Feb 12, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Unable to burn dvd using LG DVD ROM
your DVD Rom drive cannot burn DVDs because it is not a DVD burner, DVD Rom drives are different from DVD writers, if you want to burn DVD you must buy a DVD burner/writer.
Jan 10, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cd burner
You need the driver for that cd burner some how your computer lost it and also you need to clean it as well.
May 25, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Computers & Internet Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
