Question about AOpen XC Cube EA65-II Barebone
Date and time are not updating, do I have to chance battery
Where is a battery ?
  • 3,799 Answers
It is usually a small silver disc about the size of a ten pence piece ( 25 cent) mounted on the motherboard.
Posted on Feb 19, 2013
Time date update problem
There is an internal clock on the motherboard powered by a 10 year (supposedly) battery. If that battery fails, the computer loses time and date when it is turned off.
Aug 03, 2013 | Sony VAIO Computers & Internet
Time is not update when my phone is on after battery removed and insetred
In Most of the Samsung Phones, once you remove battery and reinsert you will need to set time and date again.It does not get updated automatically.
I hope your query is resolved.
You can go to setting and update time and date.
Apr 01, 2013 | SAMSUNG GT E2652
The time and date has to be set after shutting off.
The BIOS battery keeps the Date and Time correct, if the battery is flat the date and time will be wrong or you will get an error date and time error.
You need to replace the battery with a new one. Your friendly computer shop can help you if you don't know how to change the battery.
Sep 28, 2009 | Dell Latitude C600 Notebook
Computer setting of date and time unstable
Could be a flat backup setting battery (aka cmos battery)
workarround
use a program to automatically update the clock like
NetTime available HERE
Mar 22, 2009 | HP Computers & Internet
Loss of calendar & clock when no power
ok the only way to check if the battery is working on your mobo is to look in the bios, im not sure if you are good at looking into bios,or you may be wanting to get someone to look at it for you,it does have a internal clockin bios that can be adjusted to the proper time/date.If it is not holding the time correctly(usually found by checking bios after reboot) then your battery on the mobo needs to be replaced,and can be reasonable cheap. HOWEVER, chances are it might be in the O.S. and if this is true can be changed (RIGHTCLICK ON TIME IN THE TOOLBAR--ADJUST TIME/DATE),,,,,, but if this doesn't hold your time/date after another boot up then there is a bigger problem i.e. software issue. Sometimes illegal downloaded software containes a patch that fools software into thinking that its too early to try and oudate(renew) or search for updates that wont make a program work any longer. Good luck JLS
Oct 21, 2008 | Evesham Axis PC Desktop
Psp updates
Hi Baran,
You are toying with a serious chance of Bricking your PSP. Before you update, plug up the power cord to the PSP. These updates once you get them started, may take longer than you have battery. The Game disc should have the update on it. Plug your power cord up and follow the games directions. Do not try to use the PC.
Nov 24, 2007 | Sony PlayStation Portable (PSP) Console
Update of time and date
If you change it in the bios. make sure you save the settings.
If that doesnt work the battery may be bad.
Nov 16, 2007 | Intel D101GGC Motherboard
Thinkpad 380ed
1) This is a typical problem when the CMOS battery is very weak or dead, it will continually display the date and time and reboot with the same errors until you change the CMOS battery. On this model it is behind the door that houses the memory chip, above the battery, if you have the laptop turned over and battery closest to you. <--best bet, its a dead CMOS battery.
2) You can get to the BIOS to run tests, one of 2 ways, either hit the ESC key and other keys to get a 301 error or hold the F1 key and boot, you should get into BIOS. (You probably won't be able to do this until you replace the CMOS battery.) From there you can run diagnostic tests on various components.
3) Lastly, you can update the BIOS. From inside the EASY-SETUP bios you should be able to copy the BIOS part number, date, etc. Look for the BIOS update based upon model # either thru a search on the web or directly on the IBM website (a search on google of "bios update thinkpad 380ed" will bring up a link for the IBM page.) If you choose to do a BIOS update, read the directions carefully and remember not to power off the machine while the update is happening. If you've never updated a BIOS before, get someone who has to walk you thru it before attempting it by yourself.
GOOD LUCK :)
Sep 19, 2007 | IBM ThinkPad 380ED
Date/time problem on *ist d
There is a small re-chargeble battery inside the camera that charges of the main battery. Chances are that battery had just drained when the date/time reset occured, but should be fine after you recharge.
Sep 08, 2005 | Pentax *ist D Digital Camera
AOpen XC Cube EA65-II Barebone Logo
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Gareth Cockram
Gareth Cockram
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
