Question about Samsung SCH-U470 Juke Cellular Phone
Samsung Juke resetting: "Power Cycle" leaves phone useless STILL
I was advised to reset my phone to its original factory settings for music stuff, went to do it in options, and was told to enter "*228-SEND" after the phone's "power cycle" was complete. (This came up on the Juke screen). SO after entering my security code again, it started power cycling at noon. ("Verizon Wireless" logo blinking on and off, cant use phone). It's 9pm now and its still doing it, occasionally appearing to turn off completely. I need my phone and don't know what is going on HELP!! thanks
  • Anonymous Feb 14, 2009
    Same problem only my juke won't turn on it just says verizon wireless on it.
  • Anonymous Apr 27, 2009
    IT wont even let me use my password... did yours still work?
    Sniper:
  • 55 Answers
The default is always one of these code try them all the last four digits of the phonenumber last programmed in the phone aka your number or 9999,1234,4321,0000,1111 if none of those work you can go the retail store for a flash they hook it to the computer and push software to the phone to correct the issue it takes five mins and its free its a common issue for them to correct if you change your lock code from the default in the future always set up a dummy contact with it in there so that you can easily look it up also please vote for me I'm trying to work my way up to expert level and I cant without your vote please
Posted on Jun 05, 2010
How to reset samsung ht-e330k
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Feb 16, 2015 | Samsung Audio Players & Recorders
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
Samsung galaxy ace duos S6802 incoming call always busy. I try to hard reset nothing happens. Call forwarding are disabled. Please help me to fix.it
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Tips
  • The ATT Samsung SII models have an alternative hard reset that requires you to simultaneously hold down the "Volume Down" and power keys after an alternative soft reset, and then release the power button, bringing up the menu titled "Fastbook, Recovery, Clear Storage, and Simlock." Use the "Volume Down" key to navigate to "Clear Storage" and then press the power button. Press" Volume Up" for "Yes" and "Volume Down" for "No." This will reset your device to its original factory setting.
  • A soft reset on a Galaxy S phone involves pressing the "Volume Up" key simultaneously with the power button.
  • Some older Samsung models have a reset button located behind the battery cover. Press the reset button using a small, blunt object.
Warnings
  • A factory data reset removes all user data and settings associated with the current account. Make a backup of all data on your device before starting a hard reset.
May 12, 2014 | Cell Phones
Reset phone password
Hi Oliver,
May 04, 2014 | Samsung Star GT-S5233 Cell Phone
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
Apr 28, 2014 | Cell Phones
How to reset my phone password easily?
Hi Ronquillo,
Apr 28, 2014 | Samsung Galaxy Y Gt-s5360 Pink Factory...
Forgot password
remove my passward in my cell
Jun 02, 2011 | Samsung SCH-U470 Juke Cellular Phone
Samsung Juke Music Issue
Had the same problem with being able to load MP3 songs onto the phone but they would not play. Elapsed song time indicator remained at 0.00.
In Windows Media Player, select Sync Menu......then Samsung Juke........then Format. The warning states that you will lose all data. This only pertains to the songs that you cannot get to work anyway. Your stored phone #'s will still be there after the reformat.
I reformatted and reloaded the MP3's and everythings now works just fine.
Jan 28, 2008 | Samsung SCH-u740 Cellular Phone
Samsung SCH-U470 Juke Cellular Phone Logo
823 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
