Question about RCA RD2826 MP3 Player
GOOD NIGHT, I NEED TO GET Switching ADAPTER CLASS 2 POWER SUPPLY INPUT 100-240 50-60 HZ 0.3 ALTERNA OUTPUT 5.5 AMP 9.9W CD 1.8. IF SOLD FOR ME TO SEND A would Xalapa, Veracruz, MEXICO CP 91000
    Novelist:
  • 164 Answers
Check in Ebay. There are plenty of Ac power adapters for the Lyra RD2825, RD2826 and RD2840 mp3 players (it's the same for all of them).
Regards,
Posted on Jul 25, 2009
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I am trying to find the output power, watts?
    bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
    Jun 08, 2010 | Audio Players & Recorders
    Where is the fuse inside the power supply model fsp200
    The unit is only 200watt and the fuse cost about $2,Thats if there one built into it,
    The replacement power supply is about $20-00 NZD
    Probably 20minutes to fix (for a novice) depending on their skill level and tools available,
    BEST ADVICE Replace it
    Power is something you dont want to mess with because it can kill.
    The power packs are replaceable but people arent.
    Be very careful and dont mess with the power.
    I am an Electrician and I respect power.Misterdj
    Mar 24, 2010 | AOpen (FSP200-60SAV) 200-Watt Power Supply
    Adapter/power supply cord missing emachine model SP 30A speakers
    AC/DC Adapter
    Model MA-9200
    Input 120 VAC 60 Hz
    Output 9 VAC 200 Ma
    Class 2 Transformer
    Oct 17, 2009 | Audio Players & Recorders
    No manual for my amp.
    • Class-D Monoblock Amplifier
    • Bass Boost Level and Frequency Remote Included
    • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
    • Variable Input Sensitivity: 200mV - 5V
    • Phase Shift: 0° / 180°
    • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
    • High- and Low-Level Inputs
    • 1 Ohm Stable
    • RMS Power Output:
      • 500 watts x 1 chan. @ 4 ohms
      • 900 watts x 1 chan. @ 2 ohm
    • Preamp Outputs: 1 Pair
    • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
    • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
    Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
    Watts
    The MRD-M300 has speaker-level inputs so you can easily use it with any car stereo. Hook it up and hear what good bass can sound like!
    Details:
    • 150 watts RMS x 1 at 4 ohms
    • 300 watts RMS x 1 at 2 ohms
    • MOSFET power supply and output stage
    • STAR Topology for cleaner sound
    • Bass Engine® features:
      • low-pass digital crossover, 30-200 Hz, 24 dB/octave
      • variable subsonic filter (15-50 Hz in 5 Hz steps)
      • parametric EQ variable from 30-160 Hz
      • Bass Compensator enhances low-end definition
    • top-mounted digital control center with cover
    • time correction 0-10 milliseconds in 0.5ms steps
    • phase correction 0-180° selectable
    • digital readout
    • detachable front cover
    • blue power LED
    • delayed turn-on
    • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
    • speaker- and preamp-level inputs
    • gold-plated terminals
    • 8-5/16"W x 2-11/16"H x 11-1/2"D (10"D without front cover)
    • 1-year warranty
    May 29, 2009 | Alpine MRD-M300 Car Audio Amplifier
    Compaq Ij300 Power Adapter
    The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
    Jul 15, 2008 | Compaq Inkjet Ij300 Printer
    Plugs for Astra Scanner 1220U
    Ran across your request for information about the cables needed for hooking up the Umax Astra 1220U scanner. The scanner require a standard older version USB cable that hooks the scanner to your PC. The second cable is the Power Supply Adapter cable. The information listed on the Power Supply Adapter is listed below. P/N 490081-03 Input 120 Volt @ 60 Hz 0.3 amps Output DC 12 Volts @ 1 Amp Model # RWP481212 You should be able to get the scanner to work as long as you can find any power supply that has the listed Input/Output ratings, an adapter that will plug into the scanner. Hope this help you. disaksen
    Apr 07, 2008 | Umax Astra 1220U Flatbed Scanner
    RCA RD2826 MP3 Player Logo
    53 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
