Question about Drills
My bosch psr 18 ve - 2 cordless drill wont work anymore even though the battery is fully charged
My bosch psr 18 ve - 2 cordless drill wont work anymore even though the battery is full charged
4 Suggested Answers
  • 25 Answers
SOURCE: how long do I charge my 18 v PSR bosch cordless
about 180 mins or an hour and a half. if the light does not change, just make sure you put it properly on the charger base and time it for charging. Disconnect it after you are done. Usually, the light on the charger is just an indication that it is powered on.
Posted on Jul 28, 2009
comax
  • 154 Answers
SOURCE: Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Posted on Jan 09, 2010
  • 16 Answers
SOURCE: I just purchased a Bosch 18 volt cordless drill
just call 888-919-7272 and you can get it replaced.
Posted on Mar 10, 2010
Bosch PSR 1440 power drill. How do I know when the battery is charged?
Tracey,
There should be a legend on the top of front of your charger that should explain the light sequence for the charging process.
May 15, 2015 | Bosch Drills
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
How to remove necessary parts from Bosch PSR 12 cordless drill to recharge the battery?
You shouldn't have to remove any parts, except the battery itself, to charge the PSR12. I did find a breakdown of your drill that shows a 'Battery Retaining Clip' that is a heavy, u-shaped wire that goes into the front of the housing section just above the battery. It may have to be removed to get the battery out.
Nov 25, 2012 | Bosch 12 Volt Cordless Drill
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
NordicTrack 2500 R Treadmill Doesnt want to start rolling, even though the program appears to be running on the display. And on the rare occasion it does start, it stops again after 2-3 minutes.
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Jul 15, 2010 | Nordic Track Exercise & Fitness
Nov 10, 2009 | Bosch Drills
How long do I charge my 18 v PSR bosch cordless drill for as it only has a green light on it and it stays on when I put the drill onto the charger
Jul 28, 2009 | Bosch 33618 1/2" 18v Cordless Drill Tool...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
