AKG SR4000 service manual - Audio Players & Recorders
How to change frequency interference range on AKG rs 40 wireless microphone?
Go on line and search for operators manual. You may have an older unit with frequencies that were given away from the AV world to the internet world and this may ultimately be the cause of interference.
Do a search of legal frequencies for microphones
Jul 12, 2016 | AKG Wms450 Presenter Wireless Microphones
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
How to disassemble it to fix connector
On the side near the connector you find a small screw.
Just loosin it and you can pull the connector out of the housing.
Here you can find a service manual.
http://www.akg.com/mediendatenbank2/psfile/datei/39/C1000s4055d1ee2167f.pdf
Regards,
Gerard
Jan 16, 2010 | AKG C1000S Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
AKG C 451 E sometimes it cuts out. It cannot take
It might be a humidity problem.Here is a repair link:http://www.akgmicrepair.com/ Here is where the service documentation can be found :http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
Oct 23, 2009 | AKG Audio Players & Recorders
Akg handheld transmitter not working after impact
Microphone capsules are very delicate and I'm afraid it sounds like you have broken yours and it will have to be replaced. Take the mike back to where you purchased it and see if you can get it serviced or if they can recommend someone locally who does that.
Sep 27, 2009 | AKG HT 40 Professional Microphone
Excessive line crackling noise
The service manual is at www.akg.com/mediendatenbank2/psfile/datei/19/C4194055d1fa264a7.pdf. You will have to replace the wiring that goes to the cartridge through the gooseneck.
May 25, 2009 | AKG C419L Professional Microphone
Microphone cuts out
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. service@akg.com might also be able to give you more info.
May 18, 2009 | AKG Perception 200 Microphone
27 people viewed this question
 Grubhead
Grubhead
