Question about Asko W620
My solenoid switch on my toshiba aw-9500 is burn.. tried looking for replacementn but not available
  • Asko Master
  • 17,130 Answers
Please check this link for spares: Toshiba
Posted on Jan 24, 2013
How to fix error e21 with my toshiba electric washing machine AW SD130SS. It washes only. No rinse , no spin.
YOUR LID SWITCH IS GOING UPSET
CHECK YOUR DOOR LOOK AND UNDER SWITCH WIRE IS OK
Oct 06, 2017 | Washing Machines
My toshiba washing machine aw-9500 SB showing error E9. what is the solution???
Check that the level of the drain hose is not lower than the base of the washing machine. Additionally check for a water leak. If no trace of water, switch off the power, reconnect and try again.
Jun 10, 2016 | Washing Machines
My toro z4202 will not start it is not the battery as it is ok
First must sure you have both control arms are in neutral and the PTO switch is off. Depending on your model setup test for voltage at solenoid control terminal. If the voltage is present and your setup uses the separate solenoid check for voltage at each of the two large terminals while trying to crank there should be voltage on both of these if not then the internal contacts are burned and solenoid need replacing.
If no voltage at the solenoid control terminal then you need check the switches at the control arms, the PTO switch and the ignition switch.
The operator and service manual are available at the following link which contains the wiring diagrams.
Toro Z4202 (74381)
Dec 15, 2014 | Toro Garden
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can you eliminat the fuseable links at the starter solenoid? my 1988 bronco wont start replace all battery cables because the burned up and replace starter and solenoid and still wont start. where should i...
check park-neutral safety switch.
If you can jump start starter right at starter, then look at above or igntion switch. Try starting in neutral too. In case P-N switch is out of adjustment.
Aug 27, 2011 | 1987 Ford Bronco
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Cd disc drive on Toshiba laptop pops open when i try to burn disc
Please make sure you have enough space available on your disc.Please switch to a new empty disc and let me know if you get the same error.Before trying with a new disc restart your laptop and then burn with the new disc.
Thank you.
Aug 13, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Hi. I have a toshiba equium l20-198 laptop dvd burning problems
there could be 4 things that's wrong that I can think of.
1. try this first, go and force xp to take your updated drivers by telling it to install from a specific location->don't search. I will choose the driver to install->have disk->have disk->point it to the driver's location-> continue and it should install that specific driver.
2. the software you're using to burn with isn't playing nicely with your drive. try using cdburnerxp which is a free burning software and test the results of those burns.
3. the firmware on your drive is corrupted(happens from time to time). try installing a new firmware from matshita's website. remember, firmware is different from drivers.
4. the dvd drive itself is busted. try using an external drive to burn a dvd(if you have one available) or switch the drive out and see if that fixes things.
after looking at some forums, seems like this drive is ripe with issues but hopefully it's not a hardware issue in your case.
hope that helps.
Mar 07, 2009 | Toshiba Satellite A60 Notebook
IT CANN'T READ THE DVD IT BURNS
hi dear
the drivers are part of windows
what they look as though they did was rerun the m/board setup disk and install the m/board drivers
try removing the upper and lower filters
scroll down to how here
http://support.microsoft.com/?scid=k...060&x=12&y=13#
check for a firmware update
the laser may be dirty or has gone
try the drive on another computer
for firmware , here
http://club.cdfreaks.com/f86/sony-aw-g170a-firmware-1-71-firmware-available-192972/
oke
cropp
Mar 24, 2008 | Computers & Internet
Washing Machines Logo
56 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
