Question about LG Washing Machines
My LG Clean Master WD6004C wont start,everything looks to be okay,but it just dosent start,the light is on.
  • LG Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Check for maintenance of the washer:
Posted on Jan 24, 2013
2003 Yamaha R6 odometer display lights wont come on sometimes what could that be?
Look for a loose ground inside of your instrument cluster, Anon.
Feb 25, 2015 | 2003 Yamaha YZF-R6
Foot pedal dosent engage the machne
Does light come on. Still could be bad cord replace.
Nov 14, 2017 | Brother XR-65t Mechanical Sewing Machine
Car will start, will go into gear but wont move, has a new clutch.
clutch needs to be adjusted if the adjustment is good try bleeding the slave cylinder (looks like a miniature master cylinder) if this dosent work make sure you have the right size clutch in the car. hope i was able to help you.
Jan 02, 2010 | 1994 Chevrolet Cavalier
So ive had my lg gw520 for a week and it wont send texts i click send it goes red vibrates then nothing help please my dads gonna kill me
if your phone has more then 500 messages delete them this is one of the main probs of that dosent fix it do a master reset on the settings the password should be 0000
Nov 04, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Lg prada ke850 black screen
My Phone has done that a couple of times before. It would slowly start turning off more & more often then it wouldn't turn on with the same problem as you.
Turns out it was the battery as it was a couple of Months old & was out of warranty.
Aug 15, 2009 | LG Prada KE850 Cellular Phone
My dual subs wont light up and my ndual tweeters wont either
check the wire connection with the lights then bulbs okay then look on the inside of the box for an extra wire for power for the lights if that dosent work
Feb 02, 2009 | Dual XNBP12D Car Subwoofer
Daytime running lights and wipers wont work
Had the same problem with my 97 Jetta it turned out to be the ignition switch. No problems since
Sep 15, 2008 | 1997 Volkswagen Jetta
Washing Machines Logo
59 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
