Question about Hotpoint Repair Pcb / Module Wf240 Wf250 Wf310 Wf320
My wf250 will not empty? - Hotpoint Repair Pcb / Module Wf240 Wf250 Wf310 Wf320
  • Hotpoint Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 24, 2013
Wf250 will only allow a very small amount of water in and then shuts off.
Check the lint screen and water outflow from inside the tub cylinder... socks are often lodged inside the tube. Check the filter screen on the inlet hose at the faucet (tap).
May 29, 2015 | Hotpoint Repair Pcb / Module Wf240 Wf250...
How do i fix a noisy spin cycle on hotpoint wf250
Hi.
A noisy spin cycle is usually because the bearings are rumbling and/or collapsed.
Unfortunately this is not a simple job and would require a service call and probably a workshop.
Good luck.
Nomess
Sep 28, 2014 | Hotpoint Repair Pcb / Module Wf240 Wf250...
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Fitting pump to hotpoint WF250
disconnect the machine hoses and all drain put it on its side you will see the pump usually help in place by 2 screws/ 2 hose clips/ 2 wire thats it pump should cost no more than approx.18.00
Jun 30, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius wf250 won't do anything it lights up with wash symbol but doesn't fill or wash it doesn't make no noise or anything please help
open the top of washing machine and near the door on right side is a connector loose just push in and will work fine.
May 10, 2009 | Washing Machines
Hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
May 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF250 Loud banging when spinning
The hardest amount to balance is a load with just one item.Because you have nothing to counter balance the other side.So,first off,put in a normal load ,make sure your washer is level by using a level to assure it is, other wise if its not all the clothes will group in one spot where its not level ,than when time to spin you have a un balanced load.
May 21, 2008 | Washing Machines
Hotpoint WF250-Loud banching when spinning
possible broken "spider"support on rear of basket best call serviceif unit is out of warranty be sure to ask for estimate first
May 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Repair Pcb / Module Wf240 Wf250 Wf310 Wf320 Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
