HP DV6000 My Laptop is turning off & on by itself. Light is on, can hear fan functioning and 2 small quiet short beeps. After lots of test. Now is running disk scheduled (ATAPI CD/DVD Rom Drive). I don't know what is the problem and what is the next step. Thanks for all answer
    New Friend:
  • 3 Answers
It is commenly known thay the bips may refer to a Ram crash or misplaced maybe because you have laptop has been shaked unproperly. Try to check up your RAM slots ;)
Posted on Jan 23, 2013
  • 1 more comment
  • nou tali Jan 26, 2013
    Hi, Mustapha
    I don't know how to check Ram slots. The problem made me to use recovery window and still having same problem.
    Thanks for your respond.
ctf1800
  • 4402 Answers
SOURCE: 101 i-o rom error
remove the memory chip and try
Posted on Dec 17, 2007
  • 188 Answers
SOURCE: replacing dvd/cd-rom drive on gateway laptop
Depends - what gateway? the one you listed under?? Because the model you posted with already came with a DVD drive.
Reply with the model of your machine and i can probably find you help. Gateway usually has instructions on their site.
The instructions for the M305CRV are here.
That model can use pretty much any standard laptop CD if you dont mind the face not matching get a generic drive like the Sony CRX880a at
http://www.directron.com/slimoptical.html
Posted on Dec 28, 2007
YourTech
  • 63 Answers
SOURCE: Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Posted on Aug 26, 2008
  • 97 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Posted on Sep 16, 2008
vincebeach
  • 37 Answers
SOURCE: dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Posted on Nov 10, 2008
Lots of beeps on startup of HP Pavilion DV6000 entertainment pc
Beep Codes
Beep signal Additional indicators Meaning
one long, two short beeps
  • System board failure
  • Video adapter problem
  • LCD assembly failure
Jul 07, 2012 | Computers & Internet
I have two intel based hp dv6000 laptops. Both are having problems. I suspect the mainboard because everything else was replaced the last months. laptop 1: Not booting, no screen (nothing!!), no beeps,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly:
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
could be a dirty graphics card you might have remove the graphics card and clean the socket
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge:
hope this helps you
Sep 18, 2011 | HP Pavilion dv6000 Motherboard
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
My laptop won't boot. Its a HP Pavilion dv6000, when I turn it on the lights come on and I get 1 beep followed by another 2 beeps. The screen doesn't come on and the fan doesn't seem to either....
This is most likely a problem with the video device in the laptop...
A single beep followed by two or three beeps is the code for "Unable to initialize video (to display the post code)"
Unfortunately since most laptops have the video chipset imbedded in the motherboard there is nothing short of replacing the board you can do to fix it.
If there is anything else, please let me know
Jun 20, 2011 | HP Computers & Internet
I have a HP Pavilion dv6700 special/limited edition. I start it up, and all lights turn on and i can hear the computer is on. But the screen is black. And then I hear a beeping sound three times. First one...
Sounds like you have a memory problem. Either a RAM module is defective & needs to be replaced, or the slot where the RAM module goes into is not making good contact between the motherboard & the memory module, & needs to be cleaned.
Try first cleaning the RAM module slot with a non-oily contact cleaner. Leave it to dry for few minutes then install the RAM module & test if the computer will turn on. If it does not, replace the RAM module with a working one & test again.
Sep 09, 2010 | HP Pavilion DV6700Z Notebook
My hp Pavilion dv6000 keeps restarting each time and the screen is left blank all the time. I don't hear any sounds either to detect any hw failure. It's reseting each 13-15 seconds after turning on so I'm...
dv6000, NO OS stated, whY? XP?
for now we get bios going first, damn the OS.
first take the old shorted main battery out,
run on AC only. run now? fan must blow first does it?
also the CCLF go dead, at 20k hours used. black screens for ever now. CCLF is dead LCD backlamps. but fan dead is other issue.
the COin cell goes bad now, ever replace that?
HP RTC coin cell battery , tiny, a $2 fix.
they dont last for 11 years, sorry.
power button dead?
fan dead,?
screen dead. (never ever shows text)???
hdd does not spin making normal noise?
cd eject button dead.?
no beeps?
no caps lock blink codes.?
the AC pack is dead if the PC is %100 dead on AC most times
I can show you 10 to 20 more things inside that can do that.
takes a full dismantle to fix some,
My guess a shop repair is not in the cards?
Jan 06, 2018 | HP Pavilion dv6000t Notebook
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My HP Pavilion dv6000 is giving me a long beep then 2 short beeps when i turn it on. I cleaned it out and it worked for a few minutes but when i restarted it the beeps returned
If your system board fixed but come trouble again.
Sometimes flex power cable problem too.
Check out internal your system.
or Mainboard problem. video chipset.
Oct 07, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
HP dv6000 Laptop screen only starts up 1/4th of the time
The first issue you had with one long beeps and two short beeps is a memory module error. see the following HP website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01732674&cc=us&lc=en&dlc=en&product=1842155 I would replace the memory chips and try again. If you have more than one chip try booting with one at a time to discover that one of them may be bad.
Jun 14, 2009 | Computers & Internet
One long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
