Question about Whirlpool LCE4332P Top Load Washer
DOESS NOT EITHER SPIN OR DRAIN. AFTER GOING THROUGH THE FIRST ROUNDS, IT AUTOMATICALLY STOPS BUT THE LIGHTS ON THE LID REMAIN ON.THE WATER WOULD NOT DRAIN.
  • Whirlpool Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 24, 2013
2 Suggested Answers
SOURCE: PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Posted on Jun 30, 2009
Washer will work on rinse, then stops, won't drain or spin.
most likely the lid switch is faulty .there is a tab on the washer lid that lines up with the lid switch make sure it is lined up and switch is depressed . should hear a click ,if not replace switch.
Sep 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Washer is not draining the water out automatically.
check for a faulty door/lid switch. can oyo uhearit click when the lid is closed??? your probalby causing a syphin action when lowering the drain hose in to the bucket. so i probably wouldnt pay mind to that
Mar 17, 2009 | Kenmore Washing Machines
110.26842692 series 80, tries to spin while pumping out.
correctm the lid will need to be closed to spin/drain water, if your experiencing an issue that it intermittenly stops during thiscycle, possible that the lid switch is GOING bad, and not always making contact.
Dec 11, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Washine Machine does not drain
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch
Mar 10, 2008 | Washing Machines
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
Whirlpool LCE4332P Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal De
