Question about Tools & Hardware - Others
What cleaner should i use to clean my sprayer after using latex paint?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
Clean it once with water then remove the filters and clean it a second time.
When we store our machines for an extender time we use mineral spirits, even better is to add a small amount of motor oil to the paint thinner ( mineral spirits) to keep the leather packings from drying out.
Even with doing you best job cleaning there is a good chance the inlet ball will stick when you start the machine up. To fix this problem tap the inlet with a hammer. Some machine have built in plungers to do this.
Posted on Nov 23, 2014
  • 50 Answers
After you have flushed through with clean water, then clean the pump and gun filters bacuse simple flushing does not clean them, also you need to keep the filters clean to avoid pressure loss.. If you are not going to use the sprayer for more than a week, rinse it through with a 10% solution of pump protection fluid such as Graco's Pump Armour. This will help prevent the corrosion of the valves which can cause the balls to rust onto the seats. If you are going to spray solvent based materials you need to be more thorough with the cleaning as latex (or emulsion) paints will form a rubbery mess in contact with many solvents, so flush through with warm soapy water and then with the solvent for the material you are going to spray.
Posted on Nov 19, 2014
  • 75 Answers
For latex you can just use water to clean the sprayer, just like with a brush or roller
Posted on Jan 23, 2013
My Wagner sprayer Is load and won't spray never used it before but it been sitting in box for long time
Try running it with "cleaner" first. In the case of Latex paint, use water. In the case of oil based paint, use Mineral Spirits. Make sure tip is clean (without sticking anything into it). Lastly (or "firstly") read the manual for info on initial setup.
Oct 16, 2015 | Wagner Air Tools & Compressors
Will not suck the paint just air is coming out
Hello I just saw this in my inbox, let me see if I can help you-
NOTE: Whenever you are going to spray with any HVLP or cup-gun
strain paint through either a strainer bag or an Automotive strainer cone to remove any kind of debris from the paint that can clog the delivery tube that sucks the paint up from the "cup" and into the fluid needle.
yes even though "Wagner" says the Flexio will spray un-thinned Latex-
However by thinning your paint 10% to 15% you will get better coverage and the paint will move through the gun better
If you have no paint coming out try adjusting the fluid material knob on top-
Also try holding a piece of card in front of the the Tip and try all your Adjustments and you should start seeing the paint spraying onto the piece of cardboard or wall.
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating
Feb 15, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Instructions for earlex 120 sprayer
http://www.manualslib.com/manual/388222/Earlex-Ags120.html
there is your link for your spray gun in general every time you use any spray gun it needs to be cleaned run solvent through it to clean it -water for latex, paint thinner for oils remove the tip housing take out the fluid needle clean it every time so it looks like new.
As for thinning stay around 15% in general latex paint does not atomize well so I tend to stay away from latex on metal parts or like a small box and so on however yes we use latex on homes but an airless sprayer is used you basically have a style of "cupgun" thats for detail work... EARLEX AGS120 Operating Instructions Manual
Oct 19, 2014 | Tools & Hardware - Others
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
Pump will not prime after cleaning with paint thiner
Could be that your were using water based paint, so if there was any in the sprayer when you cleaned it out with thinner, this could cause the latex to become a rubbery mass that then blocks up the passage ways. If so you'll need to strip the pump and clean it out.
Oct 04, 2013 | GRACO INC TrueCoat Plus II 16N659
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
Having trouble getting a good spray pattern when I use thick latex
You have two choices to fix this problem: First thin the paint and/or add a conditioner like Floetrol to make the paint flow properly. Second, use a tip with a bigger opening. On sprayer tips there is a three digit number (.ABC). The first number (A) is one half the spray pattern size when held 12 inches from the wall. A two will give you a four inch pattern, five will give you a ten inch pattern, etc. The last two numbers (BC) are the oriface size. For latex you should be using at least a .017 or .019 tip but if the paint has to be very thick you may need a .021 or larger.
Jan 05, 2011 | Campbell Hausfeld Airless Spray Guns &...
I own this 0525151 and am trying to spray a latex fence stain. worked for a little while, then nothing. I tried thinning the paint with water and a paint thinner product recommended by the Home Depot...
We used paint sprayers every day for years.
Tips come in different sizes. With oil base paints we used the small tip like a 4-11. With latex we used bigger tips, like a 5-17. Really big spray rigs use 5-19. Tip size matters.
Another important thing is to strain the paint. The paint store sells 5-gallon-size strainers. Put the strainer over a 5-gallon bucket. Pour the paint into the bucket. Lift the strainer up, and finally grab it with your hands and squeeze the paint out. Do this in the grass and then wash out the strainer for next time. Put a lid over the paint bucket so the paint stays wet and clean.
We used high pressure sprayers, and then wrapped a filter right over the intake... but the tips would still clog. We had guns with reversible tips ... rotate the tip around, fire the gun, and the clog was gone.
Maybe your tip is getting clogged real fast. When that happens, the gun simply doesn't shoot. The old guns, we had to take them apart every time the tip clogged. I don't know about the tip on your gun.
Your paint sprayer is probably not very high pressure, which means it would clog easily if stuff was in the paint ... and latex is thick and sticky and it gets crusty as it dries.
Suggestion: I would ask Sherwin Williams about the tip. See if they sell parts or tips at the Home Depot or Sherwin Williams.
Also you can clean the gun out with lacquer thinner. See if the lacquer thinner will pass through the gun. I would take it apart and clean everything with a toothbrush, and soak it in lacquer thinner. It might work, but the home-depot-home-owner-spray-equipment is generally not made for more than a few jobs. Especially the wagner-diaphragm-type guns.
Something else you might consider for a cedar-type picket fence. A roller. Sherwin Williams sells thick shaggy roller covers that hold a lot of paint. The little cheap roller covers can't paint a fence or anything else because they're too thin. We almost never sprayed a fence. We'd put masonite along the bottom and then just threw paint up with a roller [slap it on as the customers used to claim] >>> for cedar pickets, thin the paint with water (1 gallon water per 5 of paint) so it flows into the holes and gaps. Roll the fence, and then go back and touch up with a brush or the sprayer. A paint job on a fence always looks better the next day [unlike some things] so sometimes it's best to wait 1 day before doing the brush work.
Oct 13, 2010 | Garden
I have a Campbell Hausfeld Furniture Paint Sprayer - paint is coming out without me pressing the handle - continuously spraying. When I try to press there is no pressure it just flops back and forth. Can...
The paint is too thick try thinning out the paint would be one possibillity clogged tip/filter. Also what happens sometimes is when using latex it drys fast so sometimes it starts gumming up the springs so it doesnt allow the trigger to close up all the way. Take apart clean thoroughly and use an latex dryin additive it slows down the drying prosess a must when using latex. Please give a 4 THUMBS UP if this free answer has any way helped. Good Luck and have a Great Day.
Apr 01, 2010 | Garden
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Aug 12, 2009 | Porter Cable Gravity Feed Paint Sprayer
Tools & Hardware - Others Logo
360 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
