Question about Jabra BT350 Bluetooth Headset Headset
I cant pair my bluetooth with my phone - Jabra BT350 Bluetooth Headset Headset
  • 679 Answers
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select BT350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
How can I repair bluetooth pairing
Depend on your phone brand. Some brand like sony iPhone, in some case can't pair (Bluetooth) with another device
Dec 18, 2015 | Radio Communications
I cant turn on the bluetooth on my zte sonata phone to listen to my music on my LAX MAX bluetooth speaker.
  1. Before you begin, place the Bluetooth device in pairing mode . Open the Notifications panel and tap Bluetooth . Or, from the home screen, tap > System settings and slide the Bluetooth switch to the On position to turn on Bluetooth . When Bluetooth is on, the icon will appear in the status bar .
  2. Tap Bluetooth .Your phone will automatically search for Bluetooth devices and will show all visible devices in range .
  3. Tap the device you want to pair with .
  4. If necessary, confirm that the Bluetooth passkeys are the same between the two devices and tap Pair . Alternately, enter a Bluetooth passkey and tap Pair .
    Pairing is successfully completed when the other device accepts the connection or the same passkey is entered .
Dec 28, 2014 | Cell Phones
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
I have a samsung hm1100 Bluetooth device but i cant hear music from music player ........ what to i do
Hi ranjit975896,
This happens sometimes for this bluetooth dongle , what you can do now is follow the below steps:
1 ) Switch off the bluetooth
2 ) Delete the bluetooth pairing from your phone
3 ) When you delete the bluetooth pairing , restart your phone.
4 ) Then switch on the bluetooth in your phone and your dongle
5 ) Pair the bluetooth , start the music player and check if it works.
Hope this helps ...:) Let me know in case you have any queries.
Sep 09, 2011 | Samsung HM1100 Bluetooth Headset
Cant pair bluetooth with other phones
check the bluetooth version of your phone..
some phones can pair bluetooth connections if its version are not compatible with each other.. example: bluetoooth version 2.0 cant search/find the bluetooth version 2.1. vice versa..
Mar 17, 2011 | LG Cosmos VN-250 Standard Battery and...
Samsung corby bluetooth not working.
my bluetooth,wifi and radio FM not opning after i install anew themes plz help me
May 02, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth problems
Holding down the main button while my phone searched for devices found it. I entered 0000 for the passcode and it connected.
Apr 19, 2008 | Motorola Mobility Bluetooth Hands Free...
Pairing to bluetooth
The V3C cant pair with other phones.. I have to hold my bluetooth head set on top of my phone to get it to pair sometimes and make sure the headset is in pairing mode
Nov 09, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Jabra BT350 Bluetooth Headset Headset Logo
233 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
