Question about Tools & Hardware - Others
Can i use this tool to remove grout? - Tools & Hardware - Others
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
That is one of the great potential uses of a multifunction tool. put on the 1/8 inch blade and rip it up
Posted on Jan 23, 2013
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
High Quality Tile and Grout Cleaning in Melbourne
Oct 06, 2015 | Vacuums
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
How to clean mold from shower tiles
bleach. spray it on and leave it.. make sure you have good ventilation and never mix it with anything else. if the tiles have caulking around them then you will probably have to get a grout tool to remove it and then re-grout. good luck
Nov 03, 2012 | 2002 Dodge Grand Caravan
How to remove old hard grout from walls
There is no easy method that I have found over the years. The best thing that I have found is a speciality bit made for a dremel rotary tool. I believe it is made of titaninum and it is made to cut ceramic tile. They are not cheap or fast but they will get the job done.If you are dealing with a grout that is not portland cement base then dremel also makes several carbide tip cutters that will work.
This is a time consumining project and if you try to grind it out I would strongly recommend you use a good qualility dust mask. I hope this helps you and good luck. Thank you.
Feb 10, 2011 | Home
How do you remove wall tiles
Follow following steps -
1.Decide where to remove the grout
2. Scrape the grout away with a utility knife
3.Try a rotary grinder instead.
4.Remove grout until the spacer lugs are visible.
5.Chisel tiles away from the wall.
6.Break the tile if necessary.
If the tiles are grouted, you will have to clear the grout away first. There are inexpensive tools designed specifically for grout removal. After removing the grout, use a small pry bar or a similar tool to pry the tiles away from the wall. Most likely, though, if the tiles were installed onto drywall, the drywall will be damaged during removal. Fortunately, drywall is relatively easy to replace. Once the drywall surface is ready, new tiles can be attached with tile adhesive or mastic. Regrout and seal the tile around the new tiles. *If the new tiles are natural stone they will be very porous and will need to be sealed and dry BEFORE installation.
Perbaiki lantai teraso Teraso cor di tempat Terazo and mosaic tile
Sep 14, 2010 | YouTube Videos
I have an old dremel tool model 270. I just
If you are saying that the grout tool that you bought is a bit you hoped to use in one speed dremel, I would not use it if the manufacturer of the bit specifically said not to. If you are saying that you purchased a tool that operates separately and doesn't need to be power by the dremel, that is different. I can tell you that manufacturers never tell people not to use their product unless there is a pretty good reason! So, if it is the first scenario I advise you not to use the bit in the dremel.
Nov 15, 2009 | Hand Tools
Grout in bathroom & shower is cracking, probably due to movement. What is best way to remedy this? Silicone caulking?
If it were me,I would replace the grout,but that's my job.lol
Silicone caulking will just leave an ugly mess if it's cracking in random (large)areas,however,it would keep the water out.
If you have lots of ambition you could try to patch with grout. You would need to purchase the same color of course. Mix up small batches at a time and use your finger tip to spread the new grout into the bad spots or use a small putty knife for spreading it. I wouldn't spend the money on professional tools unless you plan on doing this full time.
Even a piece of cardboard could be used to spread it.
Follow the directions on the grout package,just using smaller amounts. Apply grout,let sit for about 10 minutes,and then wipe up excess with a damp sponge. Make sure you only make one pass at a time and do it gently...rinse sponge between wipes.
Oct 08, 2009 | Home
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Tools & Hardware - Others Logo
172 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
