Question about Elmo Projectors Office Equipment & Supplies
Can I still buy a new 150watt bulb for an old Elmo Slide Projector CV and CS
150 watt bulb needed to make projector work, old one stopped working last night. It has a 15mm base like an ordinary light bulb, The full length is 85mm with the top 15mm blue. The width of the bulb is 25mm wide and 60mm long. Inside ther is a metal frame with various coiled attachments which have come adrift. Can you identify this and if so replace it ?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 23 Answers
Never tried them personally but you could try
http://www.bulb-source.com
Posted on Jan 30, 2013
  • 236 Answers
SOURCE: NEC projector LT220 - replaced bulb, works for 1.5 hrs then switches itself off
obviously what is causing the unit to shut down is due to overheating, that is your protection. the question is why does it overheats. maybe your colling fan fliter is blocked. better chek that filter and make sure it is free from dust accumulation. If that's cleaned and still the same, maybe it is your board that's why your original bulb got busted that you had it replaced. better go for the units check then or it will again damage your newply replaced bulb.
Posted on Apr 04, 2008
SOURCE: Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Posted on Oct 25, 2008
SOURCE: Elmo K 100 SM cine projector
I have photo of the metal piece where the diagramsticker is placed, where can I send this photo?
Posted on Jan 28, 2009
SOURCE: NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Posted on Apr 18, 2009
SOURCE: Short life for a Sony LMP-150
The bulb replacement message is not triggered by bulb condition. It comes on after a given number of hours use. If you did not re-set the hours counter to zero when you replaced the lamp then you will get this message prematurely. Don't replace the lamp until it ceases to work correctly - colour balance wrong it it simply does not light.
Posted on Jan 23, 2010
Panasonic FHL 6EX-N (TOP BULB FOR ELMO EV4400AF VISUAL PRESENTER. Where can I buy it and how much?
We just go these from Interlight. Their part # FHL6EX-N
INTERLIGHT.BIZ
They had them in stock and shipped the same day.
Nov 23, 2010 | Elmo Projectors Elmo projector lamp...
I bouht an old Elmo but the lens seems to be missing. How does this projector project anyway What sort of lens system? Thanks to whoever answers
The TRV-35 series are not slide projectors in the normal sense. There isn't a projection lens to enable an image to be projected on a wall or cine screen. The unit is a digital convertor for producing an image via a TV or PC.
Aug 11, 2010 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
ELMO document camera only shows documents in black and white, not color. Is there something wrong with the bulb? the camera?
My ELMO unexpectedly stops working during class. The blue power light is still lit but the ELMO is not recognized through my projector.
Any suggestions on what the problem may be?
Mar 25, 2009 | Elmo Projectors EV-200 Slide Projector
My ELMO video presenter is not working. When I connect it to the video projector via s-video cable, it no longer shows an image, but the projector recognizes there is a signal. It recently fell off of a...
you'll have to check the elmo usa website. you can either send it to elmo themselves, or to one of their authorized service centers (website). if the camera itself is damaged, it's pretty expensive. it may just be the s-video socket.
Dec 11, 2008 | Elmo Projectors HV-8000SX Slide Projector
Trying to replace the bulb
Contact Bulb Direct.com. Ask for part number 8549-1. Their number is 800.772.5267. Service info available for download from the Elmo website.
Sep 24, 2008 | Elmo Projectors TRV-35H Slide Projector
KodaK EKTAGRAPHIC MODEL E2 SLIDE PROJECTOR
You can use an ENH lamp which is 250 watts. it costs more (shop around- margins are high on lamps) but lasts an average of 175 hours vs the 300 watt ELH lamp at 35 hours.
You can also get ELH and ENH lamps from Wiko and Fuji in a "-5" version, ie ELH-5. It's built for 125 volts rather than the typical actual house voltage of 110-120 v. This allows them to burn much longer. There is a marginal lowering of light output in these forms.
Nov 25, 2007 | Office Equipment & Supplies
226 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
