Question about Planar 433ACJ30L72 Power Supply / Backlight Inverter TJ777 VP-775, 453AJ30L74
Assemble tj777 vp-775 to the lcd cables - Planar 433ACJ30L72 Power Supply / Backlight Inverter TJ777 VP-775, 453AJ30L74
Lcd no work
More than likely, the flexible cable that goes from the inside of the body to the flip out LCD screen, needs to be replaced. Time to seek Professional service. We can help!
Contact Us at AVRepair com
Jul 10, 2014 | Samsung VP-D103i Mini DV Digital Camcorder
My Marantz VP-15S1 bulb burned out (with 775 hrs remaining). The bulb was replaced with an LU-12VPS3 replacement bulb/housing unit. It worked fine for about 2 hours and quit working. When I pulled the...
the lamp is a cheap one, you should purchase a original one
we supply the Original lamps for projector since 2002
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Nov 20, 2013 | Marantz VP15S1 Lamp
My LCD was first blank(White colour),and now it dosent even work(black colour) help?
Your flat wire / ribbon cable that goes from the LCD display to the main PCB is fractured and split, thus it looses signal and as in your case the split has worsened and you have lost power to the backlight also, which comes from this very cable.
You will need to replace it and it may not come as just the cable but the entire LCD panel.
This is a common fault on many camera's of different makes.
Aug 11, 2010 | Samsung VP-D101 Mini DV Digital Camcorder
Samsung Sports Miniket VP-X220L lcd screen is
yes it can be order from your dealer
but its a verry minisious job.....
Feb 07, 2010 | Video Cameras
Samsung vp-d351
you have 2 differnet problems. white screen is a bad ribbon cable inside unit.. eject r is a bad tape transport. something broke inside or the tape transport is outta alignment.
Aug 06, 2008 | Samsung Compact MiniDV Digital Camcorder
Samsung Digital camcoder VP-D305i : LCD image blurred
OK IF YOUR PRERECORDER VIDEO'S PLAYBACK CORRECTLY THIS IS THE CCD AND CANON WILL FIX FOR FREE. THANKS TO SONY
Feb 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
I have a Sam sung digital camcorder vp - d305i.
I have used the cam 3 times and decided to use it for once and now have found no image on the Lcd and view finder but it seems to record the sound only.
What could it be???
Dec 21, 2007 | Video Cameras
SAMSUNG VP-D351
hi there macker2. i have resolved the problem myself and have E-mailed my instructions to three others to date.. the manual can be downloaded but does not give detailed instructions as to how to take apart or betterstill. to put back together!!! if you need instructions to do this yourself i will be happy to send.. stefjanet@yahoo.co.uk.. others have managed with no problems. takes a little patients and time....stefan
Oct 18, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Problems whit Samsung VP-D351 Visor and LCD in mode normal blur but in mode NITE PIX OK...? Some body knows..about this...is CCD Sensor...when repairthis....please
samsung vp-d351. lcd screen was bright white at first then suddenly went off (no picture). sound and everything else ok. can anybody help?
Aug 21, 2006 | Samsung Compact MiniDV Digital Camcorder
Samung vp-d80 no display on v/finder or lcd display
Its probably not the chips that is defective Jim.. these camcorders use those really small pana caps there called and they leak and go bad and sometimes NO NO most of the time cause the PCB to oxide and melts the pcb traces. If when you try to unsolder these surface mounted caps your gonna get a really acid type smaell thats bad smelling and bad for you too. if thats the case its bad. Good luck and please report back if you want more info.
Apr 01, 2006 | Samsung VP-D80 Mini DV Digital Camcorder
Planar 433ACJ30L72 Power Supply / Backlight Inverter TJ777 VP-775, 453AJ30L74 Logo
63 people viewed this question
Top Planar Televison & Video Experts
Electro Med Services...
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
