Question about Ridgid 300 Pipe Threader & Victaulic Ve272 Roll Groover <-- Great Shape
How do you adjust a victaulic roll groover - Ridgid 300 Pipe Threader & Victaulic Ve272 Roll Groover <-- Great Shape
    New Friend:
There are several adjustments that can be made on this tool, therefore it would be best to discuss your question over the phone with one of Victaulic's Tool Specialists. They are always happy to answer your questions! They can be reached directly at 610-559-3444.
Posted on Jan 24, 2013
Ssangyong Kyron 2010 handbrake will hold forward motion but not backward roll???
It's not expected to hold a backward roll. No hand brake will . That's why they tell you to turn the wheels into the curb to prevent a roll.Adjust the brake shoes and the cable length adjustment.
Jan 21, 2017 | SsangYong Kyron Cars & Trucks
2002 yz 125 when I put it in gear it will shut off acts like the clutch is not working when I adjust it on the handle bars it slips
Mechanical issue: clutch not disengaging completely...
engine off - put in gear and roll back and forth with clutch released does engine stop the bike from rolling? Now pull clutch lever in and try rolling again is clutch cable adjusted properly?
Electrical issue: bike thinks clutch is still engaged and kills motor when not in neutral
Is the clutch switch properly connected and working? Is it adjusted properly? Use a multimeter to read resistance across switch contacts does it change state when clutch is pulled in?
Jul 28, 2014 | Motorcycles
Ridgid 918 groover keeps flaring the end of 6" pipe works fine on all smaller sizes
GROVE TO DEEP. GO SLOW AND RESET THE DEPTH GUAGE ON TOP OF GROVER,THIS NEEDS TO BE ADJUSTED WHEN YOU CHANGE MATERIAL BEING GROVED.
Apr 03, 2014 | Ridgid 48387 918 Roll Groover for 535
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Where can i find grooving tool for autotyres
I bought one through speedway motors. they have a cheaper one, but this one is really nice and comes with several blades and is instant heat on.
http://www.speedwaymotors.com/Garage-Sale-Aussie-Instant-On-Tire-Groover-220-240-Volt,57737.html
hope this helps
Feb 16, 2012 | Cars & Trucks
The mechanism that rolls back in the power cord seems to be working slower and sometimes not at all. Was wondering if the mechanism in question has an adjustment to increase the tension on it so the power...
it easy to adjust the roll back of vacuums the problem is hard to dismantle the unit to remove all the things to see the adjustment roll,all vacuums is need to remove all screw to open the unit even to replace the small parts like switch,and sometimes we cannot adjust the roll back if the spring is worn out we need to replace the new one,for me much better call and service technician for your comfortable and practically to not damage the other plastic part of the unit.and you get a warranty service for that one.
Jan 01, 2011 | Kenmore Vacuums
Picture roll up and down
Standard CRT televisions have a vertical roll adjustment,usually on the back at the bottom.
It may look like a white finger-knob (about the size of a pencil eraser) with a small screwdriver slot in the end...or it may be a roll-wheel...either way, it will be labeled "vertical" (or just "vert").
Make slow adjustment to the vertical until the roll stops.
*Use a solid signal for the adjustment, like DVD, VCR or cable...a weak signal can cause a bit of roll, too.
Apr 11, 2010 | Sony Televison & Video
Rolling screen
Does the onscreen menu roll too? If so, vertical hold needs to be adjusted. Not sure if on this model if that's in the service menu or a manual adjustment on the motherboard. Keep searching google and see if anyone else has had that issue too.
Good Luck!
Mar 14, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Screen rolling
hi there, yes there are some adjustmet pods them, but make a mark on it before you adjust so that you can turn it back again in case you lost control of the adjustmet. ty
Dec 11, 2007 | Orion STV2763 27" TV
Ridgid 300 Pipe Threader & Victaulic Ve272 Roll Groover <-- Great Shape Logo
113 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
R Daniel Wolfe
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
