Problem for Apple iTunes
Itunes drivers for importing and burning CDs/DVDs missing
I have tried to download itunes version 8.0 several times and every time I open the program after, I receive the following message: The registry settings used by the iTunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing other CD burning software. Please reinstall itunes. But as I mentioned re-installing hasn't helped. I know that I have used previous versions without a problem, so I am not sure what to do? Can anyone help so that I can burn CD's?
Clarification Request
Posted by Mr-Sticky on Jan 28, 2009
have you tried to uninstall, reboot then install fresh?
If not, i suggest that would be worth a try
Same Problem
May 22, 2009
-   When trying this solution
Change the registry values “ When I went tothe registry entry, there was not an entry for Upper Limit so I addedone, as follows:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318}
I created a new “Multi String Value” within this key (very important to select Multi String Value).
I named it Upper Filters, and then double clicked it to add the GEARAspiWDM text WITH a carriage return"
I have problems with my DVD burner, Is this some never ending loop cuased by iTunes or Vista
-   Guest May 18, 2009
-   The registry settings used by the itunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing other burning software. Please reinstall itunes-   Guest May 05, 2009
-   Same issue here...
I've downloaded and installed the latest Gear drivers (no resolution)
I added the "UpperLimit" registry entry (this kept windows from recognizing my CD and DVD drives "a bit more important to me than iTunes" so I changed it back)
Can Apple just fix their software rather than thousands of their iTunes users having issues?
Or do they prefer making Microsoft users experience issues?-   Guest Apr 23, 2009
-   I have the same problem and I have installed gear
HOW THE **** DO I FIX THIS. it wont let me update my ipod. **** APPLE-
gokillyourse Apr 20, 2009
-   ihave exactly the same problem, dell nor apple have been any help, installed gearsoft but did not help-
sjhodge2992
Best Solution
posted on Feb 14, 2009
Rank: Guru
Rating: 86%, 92 votes
I recently had the same problem. Try installing the
GEAR driver.
Was this helpful?21 people thought this was helpful
Solution #2
posted on Feb 28, 2009
Rank: Apprentice
Rating: 83%, 19 votes
Try installing the
GEAR driver.
I tried this solution and my iTunes started recognizing the CD/DVD drive once again.
Was this helpful?6 people thought this was helpful
Solution #3
posted on Apr 10, 2009
Rank: Guru
Expert
Rating: 85%, 225 votes
http://support.apple.com/kb/TS2372
http://worldwidetech.wordpress.com/2008/09/11/itunes-8-loses-cd-dvd-import-burning-drivers/
http://discussions.apple.com/message.jspa?messageID=8526713
Was this helpful?2 people thought this was helpful
Solution #4
posted on Aug 26, 2009
Rank: Apprentice
Rating: 75%, 7 votes
Type Regedit and go Here:
Then Find NoInstallClass and Modify its Value to the number "1" without quotes.
Then Find SilentInstall and Modify its Value to the Number "1' without quotes as well. The error should be gone!
Comments:
Aug 26, 2009
- I have solution!!!
Go Here in Regedit:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ControlClass\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then Find NoInstallClass and Modify & set its value to 1
Then Find SilentInstall and Modify & set its Value to 1
That should be it!!! Happy Music Listening!
Solution #5
posted on Aug 19, 2009
Rank: Apprentice
Rating: 75%, 2 votes
to really fix this problem go to this web page
http://www.gearsoftware.com/support/drivers.php
Popular Solutions for Apple iTunes
Questions and Unsolved Problems for Apple iTunes
Do you recommend Apple iTunes?
itunes says it cant connect to the itunes store because the internet isnt connected, but it is......
(More)
itunes says it cant connect to the itunes store because the internet isnt connected, but it is... what should i do?
I cannot open itunes,a error message reads: itunes library.itl file is locked,on a locked disk,or...
(More)
I cannot open itunes,a error message reads: itunes library.itl file is locked,on a locked disk,or you do nothave permission for this file
I get the message "Windows can not access the specified device, path or file. You may not have...
(More)
I get the message "Windows can not access the specified device, path or file. You may not have the appropriate permissions to access the item." I have reinstall iTunes twice but it still doesn't work.
registry settings used by the itunes drivers for importing and burning cd's and dvd's are missing....
(More)
registry settings used by the itunes drivers for importing and burning cd's and dvd's are missing. re-enstalled itunes 9 several times still same error message installed gear drivers and retsrted the computer still same error.
Registry settings used by the itunes drivers for importing and burning CD`s and DVD`s is missing....
(More)
Registry settings used by the itunes drivers for importing and burning CD`s and DVD`s is missing. How do I rectify this? Thanks Barry
20 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Apr 19, 2009
I have the exact same problem.
Comment by sugget, posted on Apr 10, 2009
when loading i tunes the following message appears. The registry used by i tunes drivers for importing and burning cds & dvds are missing.I have tried re installing i tines but this did not work! Any ideas?
Comment by Guest, posted on Apr 09, 2009
Change the registry values “ When I went to the registry entry, there was not an entry for Upper Limit so I added one, as follows:
registrry settings used by itunes driver for importing and burning is missing.
Comment by Guest, posted on Mar 23, 2009
exact the same like me .... new update and now the same problem .
any help ?
Comment by Guest, posted on Mar 18, 2009
I have this problem and it won't show my new ipod touch
under devices
Comment by Guest, posted on Mar 05, 2009
Can't seem to burn CDs from itunes.
Comment by kittycat44, posted on Feb 28, 2009
Warning!
The registry settings used by the iTunes drivers for importing and burning CD’s and DVD’s are missing. This can happen as a result of installing other CD burning software. Please reinstall iTunes.
Comment by Guest, posted on Feb 21, 2009
itunes registry problems
Comment by Guest, posted on Feb 20, 2009
Same message, same missing drivers. I son't know what to do.
Comment by Guest, posted on Feb 17, 2009
iTunes Set Up assistant
Warning!
The Registry settings used by the iTunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing another CD burning software. Please reinstall iTunes.
Uninstalling and reinstalling iTunes doesn't work.
Comment by burtontexjap, posted on Feb 12, 2009
So I keep getting this message. I cannot burn CDs with i-tunes now. I've tried re-installing itunes several times. Shoul I just take a hammer to the laptop This is the message. "the registry settings used by the iTunes drivers for importing and burning CDs and DVDs are missing. This can happen as a result of installing other CD burning software. Please reinstall iTunes." What do I do now?
Comment by Guest, posted on Feb 08, 2009
same problem, have uninstalled, reinstalled, fixed, installed alternate CD writing software and am about to install the gear drivers - which are recommended in an old itunes fix for this problem (
http://www.gearsoftware.com/support/drivers.php).
Note to anyone who suggests uninstalling, reinstalling, turning off AV or some other equally meaningless and useless activity - please put your left hand in the nearest desk draw and kick it shut as hard as you can. If you dont know the answer then dont offer up guesses - its a waste of everyones time.
Comment by Guest, posted on Feb 07, 2009
This problem seems to be a driver conflict issue: when I installed powerdvd to my system my dvd drives disappeared. Microsoft website recommended deleting the upper and lower filters in the registry. This worked but then I got the itunes error message. After importing itunes filters back into the registry then the drives disappear again. There doesn't seem to be a fix when they share the same filters it the registry! I think this conflict needs to be addressed by Apple or Microsoft, unless there's a way to work around it.
Comment by Guest, posted on Jan 28, 2009
Thanks for asking... I tried that and no luck... :(
