Question about Fujifilm Finepix S2980
Camera dosent work due to the battery cover micro-switch not shutting off
The camera suggests switching off and then on again. the cover is fully closed and locked and i have tried at least 50 times, batteries are new ! any idea
    Genius:
  • 1,019 Answers
Paul, This is going to require a visit to your local camera shop, it is nothing that is a user fix.
Posted on Jan 25, 2013
SOURCE: Camera keeps shutting off
I have the same camera (Fuji Finepix 345) and a problem that may have been similar. When I powered on the camera the lens would extend but as soon as I attempted to take a picture the camera lens would retract and the camera powered itself off.
The camera is now working. I followed the troubleshooting steps at this address:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Gently holding onto the lens to prevent it from retracting during power off was the solution that worked for me.
My camera's problem seemed to slowly get worse over time until it finally stopped taking pictures. At first my wife and I noticed that pictures were sometimes out of focus. It turned out that my wife takes pictures using the viewfinder where I use the LCD screen. She wouldn't notice that pictures were out of focus. If I saw that the LCD was out of focus I'd power cycle, press the zoom button to get the lens to move, and/or try tapping the camera while upside down and powering on. Eventually it got so bad that we couldn't get any pictures in focus and I ended up buying a different camera. Then last night I tried the trick about holding the lens and the camera is working again.
I suggest you first see if the camera will power on when switched into playback (picture review) mode. Move the slider to the playback position and turn on the camera. Can you review pictures? If not, then clean the battery contacts by rubbing them with a pencil eraser and replace the batteries. Try holding the power button down for several seconds, it seems like my camera is slow to power on sometimes.
If you can review pictures in playback mode you'll know the problem is not batteries, battery contacts, or the LCD display and circuitry. Is the lens stuck? To jar it free, try holding the camera upside down and tapping the edge against the palm of your other hand while holding the power button down. As mentioned earlier, this used to work for me.
Good luck
Posted on Dec 31, 2007
  • 75 Answers
SOURCE: Camera switches off when I press the shoot button
Are you using NiMH rechargable batteries? Digital caemras are real battery eaters and Nickel Metal Hydride batteries are the only ones that can stand up to the drain. Buy ones with the highest power rating yu can get. If this doesn't help, then the power board has started to fail and needs replacing.
Posted on Apr 04, 2007
SOURCE: battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
Posted on Mar 24, 2008
moz205
  • 80 Answers
SOURCE: Camera switches off when i try to take a picture
Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Posted on Oct 25, 2008
SOURCE: fujifilm s5000 I want to buy a new battery door. Is that possible?
I have the same problem and after many different contraptions to try to keep it closed I simply used a ponytail holder. Just a simple brown hair elastic. (a large one) It has worked well for over a year now.
Posted on Feb 19, 2009
My camera does not turn on with the battery in it. When it does turn on it stays on for less than a minute. I have already replaced the battery twice.
Welcome to FixYa.
Two reasons why the camera automatically switch off.
1. The battery is exhausted
- try to insert fully charged battery or replaced a new fully charged battery.
2. The camera stopped due to malfunction.
- removed/ re-insert battery and switch the camera on.
For more details and troubleshooting steps of your camera, here is the link for your free manual. Just click here
I hope this solution will help.
Feel free to send us your comments and suggestions if this solution is helpful.
Thank you for using FixYa.
Apr 07, 2011 | Cameras
I dropped my camera and the "card/battery" cover fell off of my camera, I got it back on, but now my camera wont turn on, I cant view pictures or anything, its just dead, The battery is fully charged. Any...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. As you mentioned the door fell off, would recommend focusing your attention on inspecting the door switch and the plastic nib that pushes in on it. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Apr 28, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
I have a jvc gz-mc200aa I haven't used in a long time I charged the battery but when I tried to turn it on it asks me to set the time and date and turns it self off. How do I get it working again? Thanks
I think there's another factor that shuts down your system not the date. Check your micro HDD if properly inserted maybe something is wrong with it and the socket also the door that covers the Micro HDD and Battery has a switch, failure of such can lead you to this symptoms. Otherwise there's a problem with it that you need an expert to check. Good Luck
Mar 08, 2010 | JVC Everio GZ-MC200 Camcorder
Won't take pictures
I would suggest the first thing do is to replace the batteries with new ones. It sounds as though the batteries are low (perhaps they won't charge fully anymore) and that is why your camera is switching off.
It is always worth trying the simple things first :)
If this doesn't work and your camera still won't switch on please post back.
Nov 09, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
No power - it won't power on, battery is fully charged
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Oct 23, 2009 | Canon IXUS 80 IS Digital Camera
When I turn my camera on, it says 'Battery Cover Open' even though the cover is securely closed and the battery is fully charged. Any suggestions?
Hi!
The switch that detects if battery cover is closed is broken. You can open the battery cover and look under it, you should see a small hole with a small black switch in it. If you have experience in repairs and / or soldering, you can fix it yourself - just shorten the switch. If you can't do it yourself, just give it to any local camera or mobile phone repair shop, they should be able to do it without problems.
Hope this helps!
Tom
Jul 31, 2009 | Olympus FE-230 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Shutter problem
sand in the mechanism? Or other kind of wearout... If the lens cover does not open completely due to some mechanical problem, the camera will not work (there are switches to detect cover full open and full closed). Probably needs some repair, cleaning or replacing the cover gears
Sep 15, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Fujifilm Finepix S2980 Logo
66 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
