Question about Tools & Hardware - Others
What should i use for cutting fluid if i'm cutting aluminum?
    Scholar:
  • 45 Answers
A house is never complete without windows and doors. There are reasons you choose the type of a door or window you do, whether for security or for style. Companies invest heavily in machinery to make your doors and windows. Here are some of the machines that are used.Read more:
http://www.secat.net/ Aluminum Research and Testing Secat Inc
Posted on Jan 08, 2014
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
For aluminum kerosene or rubbing alcohol works great to both cool the cutter and lubricate
Posted on Jan 23, 2013
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Engine dies at stop lights when air conditioning is in use
Lets use common sense on the Trans Flushing
Old Fluid out --- New Fluid in---WOULD THAT DO ANYTHING
TO CORRECT ANY PROBLEM------NO
Trans & Power Steering Fluids-- are done every 3 years
in my world
They are called Preventative Maintenance,just like spark plugs,
gas & air filters,nothing else,fixes nothing
Trans fluid breaks down over time from heat & then your
clutches burn up & your trans fails,no other reason to change
the fluid
If the Torque Converter Clutch Solenoid is bad & doesn't
release when you apply the brake,then it is like slowing down
with a standard shift car & not putting in the clutch when you
come to a stop
You need to ask more questions & understand what your
told or stay in the conversation & take it into the service bay
& not deal with a service writer who doesn't work on the
product.
Jul 24, 2012 | 2011 Kia Sorento
My car keeps cutting off in the middle of the road while I'm driving. What could be the problem. I have 85,000 miles on my car. I've changed the oil and had the transmission fluid changed as...
Why would you tell us about engine oil & trans fluid changes?
Out with the old oils & in with the new ?
I would lean towards a fuel pump binding up & stopping
fuel,thus the car shuts off
Only one suggestion,could be other causes
Sep 21, 2011 | 2004 Chrysler Concorde
2002 Kia Optima runs great, transmission has started acting irradcally. it will shift and pull in gear for a short time after starting, but after a few minutes it fails to move the car. I've changed...
Keep driving it like that & it won't work at all
When ever you even think you have a transmission
issue,you immediately stop using the vehicle or you
end up rebuilding the trans,your call,your money & lots of it
Ask yourself ---Why would changing the fluid do anything?
Old oil out / New oil in ?
You change trans fluid because it breaks down from the heat
That is it's job,to remove heat or your trans fails
Trans & Power Steering get changed every 3 years & not
over 30,000 miles ever on ALL Vehicles
Jul 27, 2011 | 2002 Kia Optima
Steering is very stiff. I have bled the lines and replaced the fluid. Started doing it just now and then and now it does it all the time would it be my pump?
why did you replace the fluid? it could be the pump, but pressure needs to be checked. when you turn steering wheel all the way to the stop, it should whine somewhat. Make sure the belt is tight.
Jul 15, 2010 | 2002 Kia Sedona
Setting for welding aluminum
You have posted under a plasma cutter. These CANNOT weld metal, only CUT it.
Jun 04, 2010 | Lincoln Electric Century Portable Plasma...
1 push rod is steel & 1 is alum, which one is exaust?
The intake valve is the lower valve and its push rod is the aluminum one, the exhaust is the upper valve and it has the steel rod, there is no rocket science going on here, the aluminum push rod is used to cut costs.
Apr 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Tools & Hardware - Others Logo
118 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
