Question about Dell OptiPlex 740 PC Desktop
I bought a company compter and it does not allow me to do anything to the control panel, how do i reset to factory setting?
  • Official Brand Answer
  • 560 Answers
Antoniogmart,
Unfortunately, the Optiplex 740 did not ship with a Factory Restore Partition. You will need to manually reinstall Windows, Drivers and Software. Below are links to provide you with information on installing Windows XP as well as the drivers download page.
How to Manually Reinstall Windows XP
How to Manually Reinstall Windows Vista
Drivers Download Page for Optiplex 740
Drivers Install Order and Help
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Jan 23, 2013
My model AFI2538AEW fridge control panel is stuck and I cannot select anything on it.
Can you unplug and replug it back in to reset compter? It might be easier to go to your circuit breaker box, vs pulling fridge out, and turn off fridge from there. That will cause it to reset. Here is the manual for it.
http://kitchen.manualsonline.com/manuals/mfg/amana/afi2538aew.html
Nov 15, 2016 | Refrigerators
Factory reset
Go into settings, in set up there is a reset mode. Resetting to factory out of the box condition will allow you to customize to your preferences.
Nov 07, 2013 | Samsung UN46D6050 TV
Factory reset for lenovo t410
if it is a newer model computer, 1 to 2.5 years old,there is an option in your Control panel setting to allow you to do that easily. or u tuibe may have a video of step by step to change the setting back
Jun 07, 2012 | Lenovo ThinkPad T410 Notebook
Lighted control panel on front all lit up, not able to change temp settings or any other settings.
Hello Loki0228,
I understand that you are experiencing a problem with the control panel on the front of your fridge. You may want to reset it to factory settings. To do this you will need to press on the factory defaults image for three seconds. The factory defaults is located on the upper right next to the on/of emblem.
This should reset the whole unit back to factory settings and allow you to change the temp to the desired temps. If this does not work unplug the unit for 2 minutes and plug it back in and it should restart the system.
Thank you for choosing FixYa.com
Justin
May 10, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Upper control panel flickers and will not allow me to control temo
how old is spa?
if new then circuit board maybe set on a mode setting that is used when being tested in the factory, locate dipswitch block on circuit board and move dip switch for MODE, should have a layout of dip switches on reverse of lid to control box
if older then you may need a new control panel (top side)
Adam Miller, Canadian Spa Company, UK
Aug 06, 2010 | Balboa Instruments Duplex Digital Panel 2...
How to reset computer to factory settings on a acer aspire 6920 G need to wipe compter clean
you need to reload everything from your Recovery Disc. Do you have a recovery disc? If you don't have, just format your hard drive and re-install your OS. Install your motherboard drivers from the CD you have when you first bought it. Also, reinstall the programs you have. In this way, you have everything fresh like brand new.
Nov 30, 2009 | Computers & Internet
Our TrueTech TV remote came with a preset factory code that allows us to override our code in case we forget it. Unfortunately, my billiant children have figured out the factory code and are now able to...
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Jul 27, 2009 | TruTech PLV16190 Television
How to restore to factory settings
You Hit F2 when The Computer Is Booting Up then You Go into The BIOS And Somewhere In there It Should Give you The Option To Set the Computer Settings To Defalt.
Jul 18, 2009 | Dell OptiPlex 740 PC Desktop
I have a digital HD package from my cable company and have one HD box I rent and another I just bought from a friend that was originally set up with Comcast, which is a different cable company than I'm...
Each DVR or box that allows you to access anything other than broadcast analog signals (channels 1 thru 100) has to be registered with your cable company. The box has an internal device number similar to the MAC address a wireless PC card might use to connect to a WiFi network. If that number is not registered as a box allowed to be on your account, then it will do nothing at all other than display those numbers you refer to. This is done to prevent you from buying a cable box from somewhere else, instead of renting the one from the cable company. The cable company looses that "rental" money if they allow this. You may be able to contact your cable company to see if they can add that box, and will ask you for numbers on the bottom or back of the box. You may also be required to pay an additional HD charge to have a 2nd HD box in your home, even if you own the box.
The bottom line is to contact the cable company, let them know what you have, and ask what is possible.
Dec 01, 2008 | Televison & Video
Wont recieve fax
NVRAM init NVRAM init returns all stored parameters in NVRAM to factory default values or to a default ROM value, depending on the variable, and performs a system reset. Performing NVRAM init can cause the product to violate local telephone regulations. Reset the language and country/region after performing NVRAM init. ENWW Service-mode functions 265 NVRAM init resets the following settings and information: ● All menu settings are reset to factory default values, including fax header and company name. ● Factory settings such as formatter number, page counts, and factory paper settings are reset. ● All faxes in memory are erased. ● All speed-dials, group-dials, and phone book entries are erased. ● All localization settings, including language and country/region, are reset. To perform NVRAM init 1. Turn off the product. 2. Press and hold down the * and MENU/ENTER buttons. 3. Continue to hold down the buttons while you turn on the product. Hold the buttons through the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When the message Language appears on the control-panel display, set the correct language and country/region. 6. Allow the product to return to Ready before using the product.
Jul 24, 2007 | HP LaserJet 3050 All-In-One Printer
Dell OptiPlex 740  PC Desktop Logo
66 people viewed this question
Alun Cox
