Question about Siemens C300A2 C300A-2 C300A 2 Gigaset 2 Handset Cordle
Poor sound reception on gigaset C300A - Siemens C300A2 C300A-2 C300A 2 Gigaset 2 Handset Cordle
I have no ringtone and the phone is flashing base. All okay yesterday. I have tried it on the other base and it is the same, so I assume it is the handset.
check radio base where one of the bases plugs into phone line. Check power and check phone line plugged in properly.
All other bases are just charging phones. !
Nov 12, 2015 | Siemens C300A2 C300A-2 C300A 2 Gigaset 2...
Replaced factory radio with a pioneer unit. Radio reception very poor. Installed powered antenna adapter. No change. Any ideas?
Pioneer is a first line brand and should provide you the best signal. If you had good reception previusly and with a new Pioneed unit it's poor, your new Pioneer is defective!. Take it back and demand your warranty, so they should change it or repair it so it should sound perfect. DON'T TRY TO "repair" IT Might lose warranty!
Apr 30, 2015 | Cars & Trucks
Poor radio reception in 2008 toyota avalon
I had the same exact problem. Toyota changed the Amolifier that improved sound quality but not the FM Reception.
THE HARNESSES CONNECTING ANTENNA TO RECEIVER (TWO OF THEM) HAD IAASUES. REPACING THEM FIXD THE ISSUE. FM RECEPTION EXCELLENT NOW !!!!!!!
Apr 11, 2012 | 2008 Toyota Avalon
Poor reception when trying to get MW
Poor reception or with heavy noise aas the interference is very high on the MW. If there is no signal strength then the fault can be due to faulty RF in the radio, poor MW oscillator settings or a faulty IF settings.
Also a faulty antennae can cause poor reception and pick of stray signals.
Check for other interferances from household applicances.
Nov 07, 2011 | Car Audio & Video
Radio and CD player both emit a hissing or buzzing noise through the speakers like there is poor reception. However, all the local signals are found and play just fine, just the hiss!
The CD player cannot suffer from poor reception, so if you are having the same hissing / buzzing sound from the Bose system irrespective of the source you have selected , its is coming from the preamp / amplifier section.Also could be coming from the electronic source selector in the preamp section.You will need profession help
Mar 10, 2011 | Bose Audio Players & Recorders
I need an instruction leaflet for gigaset C300a duo phone . can you nhelp?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Feb 07, 2011 | Lands Phones
I have a 1970's Sony AM Receiver ICR-9. Reception is poor and sounds almost like it is receiving on another band. It has been a great radio and would like to retain. Bill
Do you use an indoor antenna ? Nowadays, with all gear around, like micro-waves receptors, strong motors, satellites, etc., reception becomes quite poor, unless you use an external antenna, properly set to catch broadcast stations. FM reception particularly has its signal much improved in that way. Correct demodulation requires a good an somewhat large outdoor antenna. Hope I could help. Good Luck.
Flavio/Brazil
Jul 13, 2010 | Sony Audio Players & Recorders
Some channel no sound
Hello Blwas5 hi, If some channels have sound and others none, its either the TV has poor reception or, its the channel's weak signal. check them both or see if your neighbors TV acts like yours. If thy neighbor reception is good, then thy TV has poor reception, you can't do anything to fix that. get another TV with good reception qualities.
Jun 18, 2010 | Sanyo Televison & Video
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Siemens C300A2 C300A-2 C300A 2 Gigaset 2 Handset Cordle Logo
118 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
