Question about Amana ARS2464B Side by Side Refrigerator
Amana side-by-side icemaker buttons on door not working properly
The water button (left) always works, the crushed button (middle) works sometimes, and the cubed button (right) works very occasionally. The icemaker is working fine. Any suggestions?
  • 410 Answers
I have an idea whats wrong but it amy be kinda hard to explain to you but here goes.
looking at the selector buttons does it look like the plastic overlay is cracked or worn from where you have made selections over time? what happens is when these selectors crack it causes teh switch to hange in one position. in your case it would most likely be the water button that is the worst culprit. the repair is very simple. you need to replace the overlay which is the sticker that labels the crushed/cubed ice and water. you can order this part through amana using your model and serial number, or post a good model and serial number here and I'll look up the part for you. thx peyton
Posted on Jan 28, 2009
LG ice maker will not dispense cubes without crushing them
Check the evaporator system, that release the cubes, when that does not work the cubes stay stuck inside.
Oct 31, 2008 | Refrigerators
Our Jenn air fridge is a few yrs old. A few
ok stop the water // the water valve is bad..very bad . change it ..its a dual valve in the back . right where the lin is hooked up . this will correct problem .. **** hope this helps . i think it will .. / feed back pls ..
Jan 12, 2010 | Refrigerators
Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Sep 12, 2009 | Refrigerators
Ice Dispenser
hi there,
check to see if you have a leak either on the inside or the outside of the freezer door.
check your icemaker line and see if anything is freezing up.
from the sounds of it, something is stopping the water flow into the icemaker.
Sep 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Amana ARS2464B Side by Side Refrigerator Logo
105 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
