The grill stopped working after it went bang and tripped the supply when turning it on. Will I need to replace the element or the switches or both?
You need to disconnect the element and check for short to the body which can confirm that the power tripped due to this short.
If the element is intact and shows good reading then check on the switch and wiring harness , disconnecting the suspected wiring will confirm as there will not be any tripping.
SOURCE: hotpoint wd72 - Keeps
We have a Hotpoint wd72 after selecting pro gramme it says starting followed by message of close door and it gives a low 'beep'
The door is closed but the machine still thinks it is open.
HELP...
Jo
Thanks - I was hoping just changing the element would do it but perhaps not. Its a Candy FPP 407N
