Question about Dryers
My White Knight gas dryer is about ten years old. It usually, but not always, works for about 30 minutes and then only lights while the ignitor is firing. Sometimes, when the ignitor is firing, if I bang the machine hard the the burner will continue to fire. I have changed the solenoids to no avail. There must be a temperature sensor somewhere that I could change. If so where is it located and how easy is it to change? I have already spent a lot having the solenoids changed and if I can't do it myself I will have to dump what is basically a good machine.
    Top Expert:
  • Dryers Master
  • 41,701 Answers
Your White Knight dryer may be suffering from old age and would not be economical to repair.
Posted on Apr 27, 2017
catriver
  • 878 Answers
SOURCE: Dryer not heating
odess, sounds like you need a new set of coils for the valve. Easy job. Remove the bottom access panel and you will see the gas valve. Remove the top screws from the coils and the coils will lift off and then unplug the harnesses. Install the new coils. Part number for your coils is 12001349. Price about 18.00 Check them out at repairclinic.com This should take care of your heating issues. Catriver.
Posted on Oct 01, 2007
  • 1028 Answers
SOURCE: gas dryer intermittently heats.
most likely solenoids after a few firings they tend to open up and not work again until after cool down replace both they usually come in a kit
Posted on Sep 14, 2008
  • 311 Answers
SOURCE: intermittent gas dryer
You are right. Gas valve coils are bad. As they get hot they malfunction as insulation has broken down. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
SOURCE: Amana dryer ignitor lights, sometimes gas catches,sometimes not
I have the An Amana commercial quality stainless dryer and mine just started doing the same exact thing. he replaced the ignitor and nothing. Now they say the gas valve needs replacing, $150-$200. He told me it looked like the roller were starting to wear and the dryer is coming towards the end of life and maybe I should look for a new one, that is B.S. My dryer is 6 years old and we only have 2 people in the house so it gets used about 2-3 time per week. I also have an Amana washer that matches (commercial stainless) and the drain pump and drum seal already went out in that last year. My diagnosis is Amana is JUNK!!! I am going to buy G.E. or something non Maytag/Amana from now on!
Posted on Nov 14, 2009
  • 3 Answers
SOURCE: My speed queen commercial dryer mod. SDG109WF is
change the gas value coil coils cost about 20.00 for the 2 you will need
Posted on Apr 30, 2010
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Drier not blowing hot air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 08, 2011 | Abbaka White Knight 44AW Electric Dryer
Hope you can help i have a frigidare 30 in stove 7 years old oven does not go on glow coil is working help thanks andrew
the "glow coil" /ignitor is weak and needs to be replaced , to get a bit techinal for a minute since the ignitor comes on at all that eliminates all other possibilities and the ignitor must draw between 3.2-3.6 amps to open the gas valve it indeed is coming on yet not drawing enough amps(getting hot enough) to open the gas valve.I base my oponion on 30 years plus as a appliance repair technician
Jul 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Hi i havw a white knight gas tumble dryer. My problem is that the flame starts for no more than a minute then turns off. Any ideas how to fix please.
heatman101'
Jun 12, 2011 | Dryers
White knight superdry dryer doesn't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Abbaka White Knight 38AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
My white knight dryer isnt heating up
heatman101
tytyy
Feb 28, 2010 | SNK Knight 43AW Electric Dryer
No Heat on a whirlpool dryer. 14 years old.drum turns,timer moves,getting gas to valve,tapped solenoids-no change.burner not lighting. thanks for any info
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
Dec 22, 2008 | Dryers
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
