Question about Insignia Pilot MP3 Player
My mp3 does not come on without being connected to my laptop.
Where can i bring it for battery repairs.
  • 20 Answers
This is a good question and I see everyone asking about insignia and dynex repair.
These two brands are made by best buy and sold only at best buy in the US.
Thus, theonly place to get it fixed is at your best buy store if you are still under warranty.
If you would like to try and fix it yourself than you may be able to find the battery online. But be prepared for sme tiny components and soldering the battery in.
Posted on Jan 28, 2009
I have a gateway mx6421 and my problem is, not charging the battery. everything works fine and the only problem is that they charge, I think the problem is the jack but not if it brings some fuse or d
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 08, 2013 | Gateway MX6421 Notebook
I was loading music to my mp3 sansa after i was done i disconnect the wire from my mp3 all the sudden my mp3 screen saying disconnected and don't kno how to take it off the screen or try to fix it
Well try it charging if does not then connect it with you computer or laptop and if computer does recieve the noticfication that mp3 player is connected then remove it safely do not disconnet wire from the player but first from computer or laptop then try it if gets on.... if doesn't without connected to computer the reconnect with computer and format your player by right clicking on the mp3 drive and chosing format button . Let me tell that there is not much possibilty that it would be working again usually Directly disconnecting gives the memory **** to mp3 player as its not furter connected to stable power supply which would explain that it won't be working or any repaires would help then
Aug 22, 2010 | SanDisk Sansa Clip MP3 Player
When I plug my power supply in it doesn't register a/c power and when you press the on button the battery light flashes orange. I am not running laptop with a battery.
Good day sir, hi, running a laptop without the battery is dangerous, it could damage the laptop, If the laptop is malfunctioning, have it checked by a service repair man, or bring it to your dealer for advice on the service of the power supply.
Nov 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
My power socket in my computer doesent work i have bought new chargers and still can get it to come on
if you just plugged in a new charger you should be able to power it on even if your battery is dead. laptops can be powered on even without its batteries as long as the chargers are connected to the laptop. i think you have to bring your laptop for servicing.
Nov 09, 2009 | Toshiba Satellite A100-S8111TD Notebook
Adapter not charging up computer
hi thanks for using fixya!
Have you checked your battery? perhaps, you need to change also the battery. Try to remove the battery then connect the AC adapter to your laptop using direct power without the battery. Just to see where is the error.
If still the same, I suggest that you bring your laptop to a service center to check the battery and the charger that you bought.
If you need further assistance, let me know!
Apr 26, 2009 | HP Pavilion zd8000 Notebook
New Battery Didn't Fix The Problem!
getting new 1 is much advisable.as reparing this will not be a garanteed reparing.it could repaired but no garantee of how much time it will work properly.
thanks.
Nov 05, 2008 | Apple iPod MA446LL/A MP3 Player
Aspire 5003WLMI No Power
you have a hardware problem which would require opening your laptop. i suggest you bring it to a computer technician who can do the repair for you to avoid further damage.
Aug 21, 2008 | Acer Aspire 5500 5570-2609 Laptop
Where can I find a new battery for my old Lyra RD2840 40GB mp3 player
The battery for Lyra RD2840 is a built in Lithium Ion Polymer Rechargeable Battery. It doesn't say removable as with other MP3 players.I believe, you will need to bring the mp3 player to the manufacturer's service center to have its battery replaced. =(
May 02, 2008 | RCA Lyra RD2840 MP3 Player
Sony Vaio ac adapter submerged
If the ac adapter was plugged into the laptop at the time may be bad news. Unplug AC adapter, take out the battery and hold power button for 10 seconds. Then connect AC adapter and hit power. If that doesn't work put battery back in without ac adapter and hit power button.
If neither test works bring to repair center for diagnosis. Best case AC adapter would need replacing. Worst case Motherboard fried.
Thanks
Mar 23, 2008 | Sony VAIO VGN-FS630/W Notebook
My creative zen neeon 2 (4GB) isn't turning ON
Try charging it with a creative charger or bring it down to its retail store. The battery might be completely drained flat.
May 02, 2007 | Creative Labs Zen Neeon MP3 Player
Insignia Pilot MP3 Player Logo
47 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
