Question about Haier HWD1600 1.8 Cu. Ft. Front Load Washer/ Ventless Dryer Combo - White
Haier 1600 washer/dryer combo error message 13
  • Jill Possehl Jan 23, 2013
    Getting message 13 when using my washer/dryer combo. clothes are coming out soaking wet so spin dry and dryer is not working.
    I am having difficulty with my Haier 1600 washer dryer combo and getting error messages 13. clothes are coming out soaking wet and they were not spin dried.
  • 43 Answers
SOURCE: Haier Not Drying
most likly to be thermostat if you remove the lid you should see 2 little round thermostats on top somewhere some stats have a reset button on 1 of the thermostats if there is press it if it clicks try it on a dry to see if it works
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Posted on Jan 31, 2009
hawk127311
  • 350 Answers
SOURCE: My portable haier dryer (HLP140E) has a bad odor.
No any smell coming from a dryer is not "normal," no matter what anyone tries to tell you. I would seek a replacement model immediately. You are not the first to complain about this model. Likewise, I would seriously consider a replacement for the washer as well, even though the smell has diminished. I hope this helps and good luck!
Posted on Nov 11, 2009
SOURCE: Haier HWD1000 washer/dryer
solved!!!! theres a flaw in the machine, lint builds up in air return area from the back of the machine to the heater, takes about 45 min to fix, take off lid and back pannel, remove weight, remove heater wires and hoses, remove plastic air return area, clean out lint, put back together, the air temp sensor is in the plasic housing in the rear of the plastic housing, the lint blocks air from circulating and triggers warning
Posted on Feb 04, 2012
manorama_diy
  • 22 Answers
SOURCE: I have a Haier HWD1600 washer dryer combo that I am getting an error 2 on. It will not drain the water out and I have not been able to clear it for the past two months
Its a common error,
Error message:Drain error, water can be not drained fully within the required drain time
Reason 1. Pump filter is blocked.
Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine)
Step 1.Push a flat blade screwdriver into the slot on the filter cover and pull it open ,do not use excessive force.(Fig 1).
Step 2.Remove the rubber hose from its clip and stand a suitable container under it, remove the bung to drain the water (Fig 2-3)
Step 3.Replace the bung and fit it back into its clip (Fig 4-5).
Step 4. Unscrew the filter and rinse it under running water, replace it and close the flap(Fig 6-7-8).
Caution:
1. The filter must be in place during operation, ensure it is in place after cleaning to avoid leakage.
2.Place a container under the drain pump filter, to collect any excess water that may come out of the drain pump when the filter is removed.
Reason 2. Drain hose end is higher than 100cm above the floor level.
Solution 2. Please adjust the height of drain hose to 80-100cm above the floor.
Reason 3. Drain hose is blocked or twisted.
Solution 3. Please check and clean the drain hose for blockage.
Reason 4. Drain hose is too long, or water is back filling from waste water pipes.
Solution 4. Remove any extension to the original drain hose.
Ensure the highest part of the drain hose is nearest the washing machine.Check the waste water pipes in the building are clear of any obstructions and flow freely.
Posted on Jan 13, 2016
Haier HWD 1600, error 7
I had this washer for almost 2 yrs and you'll end up fixing things here and there. Well after some heavy research this error was supposedly the control box or some computer chip/loose connection. After taking apart all the pieces and reassembling, still err7 comes up. Turns out our daughter liked to open the door and pull down on it, causing a misalignment. There's lock that 'clicks' when you start a load to lock the door and I'm guessing there's a sensor that takes 5 seconds to detect if the door is closed properly. Our door was misaligned so the sensor tripped the circuit after 3 seconds of the water starting. I just press the door more with my knee and start the load. After 5 seconds I let go and all is well.
Apr 21, 2014 | Haier 14.3 lb. Washer/Dryer Combo
I have a haier hwd 1600 that is giving a error code 13 what does that mean and can i reset the machine or do i have to call a service tech
I service this machine before. There is no service manual for any Haier products.
You might want to change these parts out in the unit: Main PCB board, Heater Element, Thermostat and the Condenser.
Mar 25, 2013 | Haier HWD1600 13-Pound Combo Washer Dryer
Haier umb error message
Unbalanced laundry distribution... According to the manual
Jan 21, 2013 | Haier XQG50-11 Front Load Washer / Dryer
Haier dryer shuts off after 14 minutes and has an error #13
It means there is no water. Check the hoses are not kinked and the screens on either end are cleaned of debris.
Otherwise these more internal parts are the possible causes:
1. Inspect the pressure tube from the tub to the pressure sensor looking for kinks or leaks.
2. Inspect the electrical connections from pressure sensor to the Control PCB
If you need a new pressure switch p/n: WD-7100-65 you can get it online at: www.encompassparts under 10.00 dollars
Dec 08, 2012 | Haier 14.3 lb. Washer/Dryer Combo
Ariston 1600 wd been getting noisier lately, now its sounds like a airoplane taking off and there is load knocking noises, is it worth repairing as it is a few years old now and out of warranty
Hey, ours was the same. Turns out the dryier element was loose and was causing the knocking sound....couldnt talk over the top of the noise.
About 100 to get the ariston guys out to fix it.
Was worth it for us....
Aug 18, 2011 | Ariston Technologies AWD120 13 lb. Washer...
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
Cold drying cycle in my haier
this is usally that the spade wire connector has fallen off the heating element remove the top of the machine and, check
May 28, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Need a manual or the basics on how much detergent and what to do to use my Haier XQBM22 C washer
I have a problem with my Washer dryer Combo on the front it seems like the machine froze and just says CE if you can help me with this problem It will much appreciated.
Jul 29, 2008 | Haier Washing Machines
Haier HWD1600 1.8 Cu. Ft. Front Load Washer/ Ventless Dryer Combo - White Logo
55 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
