Question about Tefal By Jamie Oliver Bl523d34 500 Watt Blender, 1.5 Litre
Jamie oliver blender - Tefal By Jamie Oliver Bl523d34 500 Watt Blender, 1.5 Litre
  • jacques schitt Jan 23, 2013
    sorry. doesn't seem to have loaded my question. i need to source new rubber gasket seal for this blender. i.e. the 0-ring that seals the glass body to the base with the blades. many thanks for any help in advance
    i rang tefal service desk on Tel No : 0845 725 8588. very chatty man directed me here :http://www.accessories.home-and-cook.com...
Need a replacement jar
  • VillaWare V001-43100 Pro Infinity Blender - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16896115006
    • 2/5
    • 2 REVIEWS
    Buy VillaWare V001-43100 Pro Infinity Blender with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Oster® Blender Parts: Find by Model ' Oster® Canada https://www.oster.ca/en_CA/parts-and-accessories/blenders Pick your model and see all of the blender replacement parts available on Oster.ca.
  • VillaWare V001-43100 Pro Infinity Blender Overview - CNET www.cnet.com > Appliances > Small Appliances VillaWare V001-43100 Pro Infinity Blender overview and full product specs on CNET.
  • Model #43100 Need a plastic Jar replacement. Where can I ... www.fixya.com > Forum > Blenders Model #43100 Need a plastic Jar replacement. Where can I find one. Where can I get replacement parts - Blenders question
  • Tilia 1000W Moderno Blender ' TheFactoryDepot thefactorydepot.com/Tilia-1000W-Moderno-Blender/M/B000GFG2W4.htm Tilia 1000W Moderno Blender: MODEL- V001-43100 VENDOR- VILLAWARE FEATURES- Moderno Pro I
  • VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz ... www.tigerdirect.com > Appliances - > Blenders - VillaWare V001-43100 Moderno Pro Infinity Blender - 67 Oz, 1000W, Speed Setting Dial Item#: YYD1-V43100 ' Model#: V001-43100
  • Oster Blender/Mixer Parts ' Reliable Parts https://www.reliableparts.ca/catalog/592809 You Are Here: Home > Small Appliances, Parts & Accessories > Oster Blender/Mixer Parts A selection of Oster ... Search by Model of Appliance:
  • Amazon.com: Customer Reviews: VillaWare V001-43100 Pro ... www.amazon.com/VillaWare-V001-43100-Pro-Infinity-Blender/product... Find helpful customer reviews and review ratings for VillaWare V001-43100 Pro Infinity Blender at Amazon.com. Read honest and unbiased product reviews from our users./>
  • Parts for the Blender at VillaWare.com. www.villaware.com/parts/parts-by-model/parts-for-the-villaware... Shop the Parts for the Blender at VillaWare.com. Food, Passion, Life.
  • http://www.bing.com/search?q=blender+Model+43100+parts&qs=n&form=QBRE&pq=blender+model+43100+parts&sc=0-25&sp=-1&sk=&cvid=F6D21CC73446407E940EA71DFB37D5F2
    May 20, 2016 | Blenders
    What is the best blender for making smoothies with frozen fruit?
    There are many types of blender available on the market which perform a different operation. Some blender is famous for specific work. I would suggest you choose the blender which can perform all the blending operation perform in the kitchen. Ninja Professional Blender BL160, BL660, BL482, Cosori High-Speed Blender.
    This all is the best budget blender for smoothies. You can get the comparison of all these blenders in one place, then you can choose the best one which is suitable for your kitchen.
    k2-_dc60fae0-5edf-426c-815f-45fa26bb0c57.v1.jpg-a8dba74604930421996186d49210837d5e1c6aed-optim-450x450-1idkyi3fqqfoabkjwactfx1g-2-0.jpg
    Jul 28, 2015 | Vitamix Blenders
    Trying to locate shipment
    suggest you contact where ever you placed that order but it's not with FIXYA.com
    Mar 11, 2015 | Sharp Oliver Bread Slicer Replacement...
    Plastic lids sticking
    I'd be tempted to try the smallest amount of olive oil, applied with a paper towel to both surfaced worked into threads. You need very very little. Alternatively get some different jars!
    You can get food safe grease but it's very expensive and usually used industrially
    Apr 04, 2014 | Blenders
    Blade stuck in nutribullet
    I took it apart by removing the rubber spindle and three small screws. Then soak it in vinegar and rinse to remove food gunk. Lastly, re-lube with cooking oil (I used olive oil) by pouring onto back shaft and spinning the blades to suck in the oil. Reassemble. I still have to replace mine as the spindle is loose due to the bearings being worn out but at least it is useable again until then.
    Feb 21, 2013 | Magic Bullet Nutribullet Blender
    Oiling the shaft. manual referred to vaselene oil. Is a couple of drops of Olive Oil an alternative?
    go to your local hardware store and get a small can of 10 weight furnace fan motor oil,it has a spout to help direct it to the oiling point too
    Apr 11, 2010 | Bamix Gastro 200 Handheld Blender
    What oil do I use to put in the shaft?
    Singer sewing machine oil, a very light food grade oil, or light grade mineral oil.
    Do not use cooking oil, baby oil or olive oil as they are all too "heavy"
    Dec 03, 2009 | Bamix Mono Handheld Blender
    HEALTHMASTER 100, CAME APART IN 8 MONTHS.
    I have been thru the fire about this! I sent my Healthmaster in recd another and it failed also. Almost always..it is the bearing that fails in the caraffe that supports the blade. The bearings that Jack Lalanne had installed in China..were not sealed...so they would allow water to enter corrode and eventually all of your blenders contents would come out thru the bottom! Or another thing that can happen is your blade will freeze up due to corrosion....and become immovable.
    Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..lalannes distributor..BECAUSE they authorized me sending my belnder back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up teh dough
    So I doubt you can receive any money.
    But this is what you CAN do!
    1) If your motor functions well..you can buy a new carafe for 45 dollars or so from Cooking toys ( google cooking toys and it should come up)
    2) OR if your cheap like me...and your blade doesnt rotate easily due to corrosion and your caraffe isnt leaking much...put a couple drops of oil on the outter rim of the bearing ( That would be located directly on the bottom of the outside of the caraffe..it surrounds the knurled metal part that is inserted in the motor for blending.
    My blade was corroded and leaking a tiny bit..I put some olive oil on the bearing and it worked great! I have ben able to use my caraffe for a month now...when I expected to have to buy a new one from "Cooking Toys" Which I will do if this one fails.
    3) If you buy a new caraffe form cooking toys..my advice? OIL THE BEARING WITH A LITTLE OIL...(any kind of vegetable oil) AFTER EACH TIME YOU USE IT! I SUSPECT IT WILL LAST INDEFINITELY>>>BUT TIME WILL TELL!
    Jan 24, 2009 | Jack Lalanne Health Master 100 Blender...
    I received a Jack La Lannes Health Master 100 Blender last Christmas and I was using it on Christmas this year and the motor started smoking.  It says it has a lifetime warrantee on the motor and I think I...
    Take your motor to a small appliance repairman. It might just be a loose wire..inside that needs replaced or re connected then follow my tips below.
    Jack Lalanne healthmaster is out of business. I manged to get a refund form Tristar..Lalannes distributor..BECAUSE they authorized me sending my blender back for a new one...and then they cashed my shipping check and then threw out my blender!!!!! I also had to call for weeks till I drove Tristar insane...so they ponied up the dough
    Jan 06, 2009 | Jack Lalanne Health Master 100 Blender...
    Product motor failure
    I wish I could tell you a definite solution. Have you tried calling 973-575-5400 (ext 129)? I realize it isn't toll-free. According to several web sites, the manufacturer has discontinued the product, but they should definitely still be supporting the motor warranty.
    Mine is eating the bearing in the bottom of the pitcher. That seems to be everyone's most frequent problem although mine hasn't actually started to leak yet. The motor is just fine. I suspect Jack Lalanne started getting complaints about the pitcher bearing and dropped his support for the product because of that.
    Dec 23, 2008 | Jack Lalanne Health Master 100 Blender...
    Tefal By Jamie Oliver Bl523d34 500 Watt Blender, 1.5 Litre Logo
    Top Tefal Blenders Experts
    eyecam
    Are you a Tefal Blender Expert? Answer questions, earn points and help others
