Question about JBL Prx625 Prx 625 15" 2-way Powered Loudspeaker
JBL Prx 625 clipping
Limiter
3 Suggested Answers
technical114
  • 1851 Answers
SOURCE: my JBl PRX 515 has
Your speaker is an active one. This means that it has indepented amplifier for low and high frequencies. So maybe the woofer (low speaker) is still active but its amplifier is defective. In order to make things more clear take a look at this block diagram to understand the signal flow:
I suggest you to unscrew the screws at the back panel and eject the whole electronics from the inside:
Take care the cables that connect the electronics with the speakers. If it's easy mark what goes where and unplug these cables. Now with the electronics on the table try to locate fuse(s) that may have been blown; since you don't smell burned components, fuses is the most common problem. Replace any blown fuse with the same one and put things back in the proper order. In case that you don't locate any fuses the problem is at components and I can't be sure if you can manage replacing components.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 13, 2010
SOURCE: how do I check and replace blown fuse - jbl prx 625 - it just shut down - would not start up again
there is fuse insert at the back where you insert the power cord ;)
Posted on Jan 23, 2013
Hi jbl prx525
http://www.jblproservice.com/navigation/PRX-Series.html
This is the exploded view, what seems to be the issue??
Jun 20, 2014 | JBL PRX525 Speaker System
How do I check and replace blown fuse - jbl prx 625 - it just shut down - would not start up again
Same thing for me... kid pressed MIC input middle of dance and it shut down. Can't find out where fuse or reset it (not even shown in breakout diagram)
Oct 20, 2012 | JBL Prx625 Prx 625 Dual 15" 2-way Powered...
No more subs in jbl prx-512m
First check the speaker with a multimeter.
If it is OK, then check/repair the Class D amp that drives the speaker,
up to the input stage.
There are board part numbers printed on the PCB and some are
available on line.
Have a tech to guide you ,should you feel to Diy.
Oct 17, 2012 | JBL New Jbl Prx512m 12 Powered Monitor...
Pull the input plate off of the back, there are usually light bulbs in there that act as fuses
I have a pair of jbl 512m speakers one is louder than the other one but it works
Make sure your audio interconnecting cables are XLR or TRS balanced lines. Use of TS cables similar to guitar cables with only two conductors (only the tip and the sleeve) reduce the gain 6 DB and contribute to hum and noise.
Sep 03, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
My JBL PRX 635 Speakers at all event shuts off during high volume ( No Red Light ) Very Embarrassing during the dance is packed. Volume is always set at one single yellow peak from the mixer and just...
Sounds like you're over driving them. First check to make sure they're on "line level" not mic. Shutting off is amp(s) in speakers going into "thermal shutdown" IE: overheating. According to your description level settings look good - check to make sure speakers are on LINE LEVEL
Apr 12, 2011 | JBL PRX635 Speaker PA Active
JBL Prx625 Prx 625 15" 2-way Powered Loudspeaker Logo
23 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
