Question about Tools & Hardware - Others
When was the lathe first used? - Tools & Hardware - Others
    New Friend:
  • 152 Answers
It was known to be used in ancient Egypt, possibly even earlier
Posted on Jan 23, 2013
I have a Ryobi ml618 wood lathe and need to know if they sell different chucks for it like a bowl Chuck
Ryobi Lathe Parts‎
www.wow.com/Ryobi+Lathe+Parts‎
Search for Ryobi Lathe Parts
Look Up Quick Results Now!
Oct 19, 2015 | Ryobi Drills
I need a tool for turning inner orings on my micro-lathe. The oring size is a buna 012 to give an idea of the size. The lathe I am using is made by Taig and has a tool holder.
You may use a high speed boring tool that is resharpened for the width of the o-ring. And back relieve up the boring bar so as not to hit your part bore 3_15_2014_8_58_02_pm.png
Mar 12, 2014 | Tools & Hardware - Others
Coronet major lathes
That site no longer seems to offer the manual... and I think I'd be hesitant about giving them a credit card number...
Aug 01, 2013 | Tools & Hardware - Others
Ammco
Most likely you have a stripped out "disc feed screw."
This is a common problem I see several times a month in the field.
The stripped out portion of the screw is near the end of the feed range obviously.
If you need parts or more questions answered....
Buy Sell Used Brake Lathes Brake Lathe Parts
Jan 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
Instructions for changing an ammco 3000 brake lathe to a 4000. Parts needed?
Yes, an Ammco 3000 brake lathe can be converted over to a 4000 model--most any year 3000.... preferably the later years after 1970.
The problem with some of the early 60's models is that the cross-feed bore is not perfectly perpendicular to the spindle.
If you convert one of these models, you will cut the rotor at an angle and then jam the machine.
Later models can easily be converted.
You will need...
1) A complete disc feed gearbox.
2) A driven pulley (the big one) set-up for a with a pin drive.
3) A complete spindle lock assembly for the Infimatic gearbox.
4) Possibly need a longer guide bar for the cross-freed. If you have a round guide bar, this is possibly long enough. If you have a "Double-D" guide bar (flat on each side), you most likely will need a longer bar.
5) A complete twin-cutter, with tool guides, tool holders, knobs, etc.
We have all the parts you need for a conversion--or we can convert it expertly for you...
Aug 03, 2011 | Ammco Combination Disc/Drum Brake Lathe
What is diffrent between lathe machin & cnc machin
A Lathe machine turns a piece to be worked on usually along its longest axis. An operator or machinist manually moves a cutter or other tool against the rotating piece to remove and/or polish the material to a more refined state. Instead of manually, a Lathe can be controlled by computer with the speed of rotation and positioning of the cutter or other tool being done according to a program or set of numeric data in which case the Lathe would then be a CNC machine. A CNC machine can refer to any computer controlled machine which uses a set of numeric data to determine its operation which can be cutting, drilling, milling, etc.
For a more comprehensive description go to Wekipedia for Lathe at http://en.wikipedia.org/wiki/Lathe
and for CNC at http://en.wikipedia.org/wiki/Numerical_control
Jan 31, 2011 | Computers & Internet
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
I need a manual to repair my tos trencin lathe sn-40a
I am looking for a tos trencin taper attachment for a 20" lathe. Got any ideas?
Apr 15, 2010 | Ammco Combination Disc/Drum Brake Lathe
I got an ammco 3000 i just have 1 bit on it and i dont have any item number on boring bar,bit holder i just have the bit size that is a little bit small than 7/16 that is 55/128 from base(bottom)to the...
If you live near a machine shop any lathe operator can steer you in the right direction, or you could call them. I'm not certain if Ammco is still in business. I had the same machine in my shop in 1976, not the same model # of course, but a model with the stand.
Aug 22, 2009 | Ammco Combination Disc/Drum Brake Lathe
Noisy headstock on 15 inch variable speed lathe
Usually not. Is lathe leveled, and base secured, check for soft feet. This can set up vibration and load bearings.If motor is belt drive check belt condition, pulley alignment, belt tension.
Jul 29, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
66 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
