Question about Ariston Technologies AL128D Margherita 2000
Drive belt comes off every off so often
AND 12 Advantage
  • Ariston Tech... Master
  • 17,130 Answers
Please check and see the alignment of the pulley and belt, Check for friction of the drive shaft which can cause the belt to slip over.
Click this link: belt replacement.
Posted on Jan 23, 2013
12 volt battery light illuminated
Faulty charging system for the 12 volt system check altenator or drive belt for slippage
Nov 07, 2016 | Cars & Trucks
Belt Position on Drum of Kenmore Advantage Dryer 68738
Check to see if the motor is bound up.
What is the model number listed inside the door?
Nov 06, 2012 | Kenmore Dryers
How to change the water pump? what has to come off first,second third etc.
I have a 1997 Rodeo so I'm not sure it is the same, but if your waterpump is located under the timing belt cover like mine is and is driven by the timing belt ...
1) Remove the upper fan shroud
2) Remove the (4) nuts then the cooling fan assembly
3) Remove the power steering drive belt
4) Remove the air conditioning compressor drive belt
5) Remove the generator drive belt
6) Remove the fan pulley assembly
7) Remove the crankshaft pulley
8) Remove the oil cooler hose
9) Remove the timing belt cover
10) Remove the timing belt pusher
11) Mark where the timing belt is currently seated in the cam and crankshaft gears (be real sure you know what you are doing here!!!)
12) Remove the timing belt
13) Drain the radiator
14) Remove the waterpump
Mar 01, 2011 | 1999 Isuzu Rodeo
I have a 3x21 inch craftsman belt sander. It's about 12 years old. With the sand paper belt is mounted and tightened and I start to sand something the belt will slip and not sand. I checked the tightening...
The drive and guide rollers are probably drying out and won't grab the paper. Take the drive roller of and treat it with a rubber restoring compund. The roller should not come off easily.
Jul 29, 2010 | Garden
I WAS THINKING ABOUT PUTTING AN OPEN BELT DRIVE PRIMARY ON MY FLHRC WOULD THERE BE AN ADVANTAGE WITH LESS VIBRATION OR ?
Open belt drives are for one thing and, in my opinion, one thing only, looks. Personally, I wouldn't have one. They look plain dangerous to me.
The biggest problem people have with them is belt breakage. Harley came out with two models that had dual belt drives, the Surgis models and the FXDG "Disc Glide" in 1984. Both models used the same type of belt drive which was a fairly narrow belt. Owners were plagued with belt breakage problems and some even converted the bikes to chain drive like the rest of the bikes Harley made had on them.
I'm sure belt drives have improved since then but as to what the advantages of a belt drive is over a chain drive, I have no idea. Some say that it reduces maintenance, a claim that I don't buy. My vote is against it but then, It is your bike.
Jan 10, 2010 | 2008 Harley Davidson FLHRC 105th...
Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
May 31, 2009 | Garden
How to install drive belts to 1996 nissan quest
go here for help
http://autos.groups.yahoo.com/group/villagerquest/files/
Item Part Number Description 1 — A/C Compressor Drive Belt Idler Pulley Adjustment Bolt (If equipped)
(Part of 8678) 2 — A/C Compressor Drive Belt Idler Pulley Tensioner Bolt (If equipped)
(Part of 8678) 3 8678 A/C Compressor Drive Belt Idler Pulley (If equipped) 4 8620 A/C Compressor Drive Belt (If equipped) 5 2E884 A/C Clutch Pulley (If equipped) 6 10346 Generator 7 10344 Generator Pulley 8 11719 Generator Adjustment Bolt 9 — Generator Locking Bolt 10 8620 Generator Drive Belt 11 6312 Crankshaft Pulley 12 — Water Pump and Power Steering Pump Drive Belt Adjustment Bolt (Part of 8678) 13 8678 Water Pump and Power Steering Pump Drive Belt Idler Pulley 14 — Water Pump and Power Steering Pump Drive Belt Idler Pulley Locknut (Part of 8678) 15 3A733 Power Steering Pump Pulley 16 8620 Water Pump and Power Steering Pump Drive Belt 17 8509 Water Pump Pulley A — Tighten to 16-20 Nm (12-15 Lb-Ft) B — Tighten to 33-37 Nm (24-28 Lb-Ft)
Mar 28, 2009 | 1996 Nissan Quest
Diagram for fan belt repair
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Aug 25, 2008 | 1998 Ford Escort
Washing Machines Logo
67 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
