Question about Hotpoint Dryers
Won't turn on
Tried switching it on but it won't turn on
  • 108 Answers
Hi u could try taking lid off look inside were swtich is to see if its un cliped out panel if yours is a button start pull plug 1st hope this helps
Posted on Feb 14, 2014
2004 Honda Odyssey won't start or try to turn
You tried it in neutral but did you take it out of park and force it back into park? Just a suggestion since sometimes the switch that tells it that it is in park needs a bit of a nudge sometimes.
Sep 09, 2013 | Cars & Trucks
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
2003 lexus es300 won't start... radio lights and windows work. Tried a jump start, still doesnt work...
Are you saying the engine cranks but won't start, or the engine won't crank ?
If the engine does not crank, you would check for voltage at the starter, the neutral safety switch, and the key switch as well as the ground connections.
Sep 18, 2012 | 2003 Lexus ES 300
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
Mar 25, 2012 | Bose QC15 Headphones
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
May 26, 2011 | 1991 Lexus LS 400
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Dryers Logo
55 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
