Question about Home
Why is there no water coming out of my cold water faucets for the bathroom over the garage. Warm/hot water is coming out of the hot water faucets. All other faucets are functioning in the house. temperature outside is high teens.
  • 5,245 Answers
1) Clogged pipe?
Bad faucet cartridge?
Take apart pipe at shut off and see if there is water.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) Add a comment and say what you find.
Posted on Jan 23, 2013
  • 171 Answers
SOURCE: Plumbing - no cold water from cold water tap
Hi blondi_1452,
I'm Harvey the Master Plumber.
Your question is: Why would the cold line water be luke warm?
In 30 years I've seen this maybe 10 times. It is relatively rare. But each time it was a cross connection between the hot and cold water lines. It could be this fixture is close to the hot water heater or the cross cnnection is in a faucet or it is in the way the water lines are piped. Anyway I would have to closely inspect the system while running the water in the fixtures in different combinations. Once the cross is located the easiest fix at this point is installing a check valve at the right point. You might consider utilizing thr Repair Directory to find a repairman. Make sure he has solved this type of problem before.
Feel free to contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 75 Answers
SOURCE: Kitchen sink only running with the sprayer
It is hard to be certain without knowing the type of faucet, but if you have the type that has a single lever, it could be 2 things I can think of. If you have seperate knobs, I can only think of one. If you have the type with knobs, take the aerator screen off the end of the faucet, The screen may be plugged with saw cuttings of pvc or what ever type of pipe, or even the water saver orifice may be stopped up. If water runs freely with aerator off, you obviously have a problem there.
If you have the lever type, the ball valve can be in backwards, or even a little way off, and the water can not get to the faucet. I am guessing, the whole faucet assembly MAY be in backwards, but that too can usually be fixed by changing the ball around.
Hope this fixes you up!
Posted on Dec 21, 2008
  • 10865 Answers
SOURCE: clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Posted on Jan 18, 2009
  • 11 Answers
SOURCE: Fowl smell in bathroom
Fowl smells related to plumbing can have several causes. Here's a few potential issues that you can check. If none of them solve the problem you may need to call a plumber.
1) Look at your pedestal sink drain connection. Is there an an elbow connecting to your drain or a P Trap? A p trap is a pipe shaped like the letter "p" (hence the name) and it prevents sewer gas from rising into the bathroom. **sometimes an apprentice plumber puts in a pedestal without a p trap because they are fairly difficult to install, and ALL fixtures need P traps. If there is no P trap, then you need to put one in. It will be a tight space, but you may be able to do it yourself.
2) Do you have a floor drain? If so, your sink will need a trap primer at the drain. Or you can pour water into the drain from time to time before it evaporates from the trap
3) If the smell is more of a sulfur type smell and it appears from running water in other places in the house, then it could also be due the type of tank you have if you are on well water
My offhand guess is that number 1 is your issue.
Without further info, those are some of my best solutions so far, but if none of these are potential solutions, then make the following tests
1) close the door to the bathroom and leave it for an hour or two. Return to the room. Do you smell sewer smell? Is it in the entire room or more concentrated in a certain area? If you don't have a floor drain and its everywhere, there could be a missing P trap from a fixture, a lose toilet flange, a cracked drain pipe
2) without running water, smell your drain. Does it have a sewer smell? Then the P trap either is not present or you need to clean the drain with a drain cleaner due to a list of reasons
3) run water. does the sewer smell increase or does one suddenly appear. Is the smell more a different odor than sewer. See if it is the water itself. If so, check other places. If they do not have the smell then you may have recently installed your sink and there is some smell related to the new valve. Then you would need to use it some more until it disappears.
Check the top list, though because I really think you're just missing a P trap
Sewer breaks below the slab, an open pipe somewhere, some issue with the water supply, are among some other issues but that depends on the test
Posted on Jun 28, 2009
  • 69 Answers
SOURCE: I have poor water pressure from the faucet, hot
could be a number of things.
most mixer taps have flexible braided inlet hose's make shure there not kinked.
also there may be built pressure reducing valves,usually removerable,a plumbers job really.
is there servive valves on hot and cold if so make shure there fully on.good luck ,any qs ask
Posted on Aug 09, 2009
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
We have 3 bathrooms, two are close to the rinnai, one is further away. The one that is further away in the early morning fails to get hot. We run the water for 15 minutes and then still sometimes no hot...
chances are that you have a bad faucet that is drawing water from a cold water tap. You will need to have a helper turn on the hot water in that bathroom while you feel the pipes at the water heater and see if they are heating up. If they feel like there is no flow, the water is coming from somewhere and you will need to turn the shut-offs of at various sinks to target the problem faucet. If you find which cold water line is acting up, install a back-flow check valve so the water goes only one way, toward the faucet.
Feb 07, 2010 | Rinnai Heating & Cooling
Severely reduced water pressure from lavatory faucet
Take the strainer off the spout and check to see if there is any dirt or rust buildup in the strainer. This happens when repairs have been done. It usually collects at the first place the water comes out of.
Nov 07, 2009 | Elements Of Design Chicago Polished Brass...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Hi, i have a problem with the hot water in my bathroom, & nowere else . The hot water in my bathroom comes out rusty, but not in my kitchen
Chances are you use the kitchen hot water a lot more. Flush the bathroom hot water line by running it til the water gets cold a few times. This should remove the rust. Also, do this with the screen removed from the faucet.
Sep 14, 2009 | Dishwashers
Shower problem
This must be a joke because there is no way the shower is connected to your faucet. the faucet on you vanity is connected directly to your hot and cold water supply. And only by opening the hot water side of the faucet can you get any hot water.out of the faucet.
Aug 01, 2009 | Home
WE HAVE CHANGED THE THERMOSTATS BOTH OF THEM, WE HAVE CHANGED BOTH ELEMENTS AND THE WATER STILL DOENT GET HOT ENOUGH. WE HAVE TURNED UP BOTH THERMOSTATS AND STILL NOT HOT ENOUGH. WHEN YOUR RUNNING THE HOT...
WE THOUGHT WE NEEDED ANOTHER THERMOSTAR, BUT WHEN WE WERE LOOKING FOR THE PART THE EMPLOYEE ASKED WHAT WAS THE TROUBLE. WE EXPLAINED, HE SAID YOU DEFINATLY DO NOT HAVE A PROBLEM WITH YOUR TANK AND ASKED IF WE HAD A SINGLE HANDLED FAUCET WITHIN THE HOUSE. NO WE DONT. HE SAID IT SOUNDS LIKE WATER IS MIXING WITH THE COLD WATER THATS THE REASON FOR THE WARM--COLD--WARM WATER. COME TO FIND OUT SINCE WE ARE REMODLING THE BATHROOM, WE HAD BOTH THE HOT AND COLD WATER TURNED ON IN THE SHOWER--BUT WERE PLUGGED OFF AT THE SHOWER HEAD AND THE FAUCET UNTIL THE TILE IS INSTALLED. SOOO ALL MY HUSBAND HAD TO DO WAS TURN OFF THE WATER IN THE SHOWER. NOW WE HAVE PLENTY OF HOT WATER, NO WARM COLD. YEA!!!
Jul 06, 2009 | Whirlpool Water Heaters
Home Logo
113 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
