Maytag MAH22PDBWW0 code f-21 - Washing Machines
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Posted on May 21, 2012
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
How do i fix code f 21 on my maytag 4000 series?
John_Cross... what a strange response. Do you just like to hear yourself talk. It's a forum ... whatever is being requested, we can all help out. Thank you Cindy Well... your link and actual action-oriented advice is helpful. If anyone has thoughts on my issue with my washer, I'm all ears. http://www.fixya.com/support/t24434057-maytag_epic_damaged_wire_harness
May 20, 2014 | Maytag Washing Machines
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
Maytag washer throwing fault code 21
May 20, 2012 | Maytag Washing Machines
Maytag epic II washer error codes, especially error code F 21
HI. Click here to download the complete service manual for this unit. All the repair procedures and error code definitions can be found in this repair manual. I would advise to save this PDF to your HD for safe keeping.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Any idea what F 21 code means
When Washer drain time exceeds 8 minutes the water valves turn off and code F 21 is set.
Dec 21, 2009 | Maytag EPICz 6.7 Cu. Ft. King-Size...
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
F-21 code? maytag epic HE front load
this code means a long drain time, check that there are no obstructions and the pump is working ok
Nov 08, 2009 | Televison & Video
Washing Machines Logo
Top Washing Machines Experts
