Question about ViewSonic Cell Phones
Display red color - ViewSonic Cell Phones
No red color displayed
If all software setting done perfectly but till color problem in your monitor, then need to call monitor technician. It may occur from crt neck base loose contact or bad contact. need to replace new one.
normally no need to discharge crt capacitor for repairing dry soldering.
Apr 10, 2012 | LG Studioworks E700S 17" CRT Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Mar 23, 2008 | Akai LCT3785TA 37 in. LCD HDTV
Viewsonic Projector not displaying RED
Hi there
This could be a problem on the Mainboard - because all the proccessing from your inputs is done on the Mainboard.
Try replacing it , I'm sure you'll have joy then.
Dec 28, 2007 | ViewSonic PJ551 Multimedia Projector
DISPLAY
Your phone's screen connectors might have a problem and need to be replaced by new ones or they need to be placed correctly. this might have happened due to a fall of your phone on the ground.
Oct 07, 2007 | Nokia 6670 Handheld
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Cell Phones Logo
Top ViewSonic Cell Phones Experts
William Alequin
Are you a ViewSonic Cell Phone Expert? Answer questions, earn points and help others
