Factory mouse and keyboard won't work on emachines desktop
Factory mouse and keyboard won't work, after power outage.
    Problem Solver:
  • 12 Answers
I assume this is a wired keyboard and mouse, not USB. It is possible that the BIOS (controls the hardware) memory has gotten scrambled. On the motherboard is a 3-pin connector with a 2-pin block jumper, usually near the battery, that will reset the BIOS memory to the factory defaults. It should be marked "BIOS", "CLEAR", or "RESET".
Turn the COMPUTER OFF. Move the jumper on the 3 pin connector from the first 2 pins to the last 2 pins. After 5 seconds, move the jumper back to the original position. The BIOS should now be reset.
If you can't find the jumper, you can also remove the nickel-sized battery that powers the BIOS memory.
Posted on Jan 23, 2013
  • 52 Answers
SOURCE: Keyboard is not working.
there are indicators to see wether that keyboard are working, check the tree LED rigthht side upper of your keyboard, this indicators should ligth evrytime you log on, if not, use the warranty to change a working one.
Posted on Jul 13, 2008
SOURCE: I have purchased a Microsoft
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Posted on Jul 16, 2008
  • 258 Answers
SOURCE: Keyboard and Mouse stopped working
Are the Mouse and keyboard Wireless??
Posted on Jan 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Keyboard/Mouse not working after power supply replacement
Hello there:
ok first remove both the keyboard and mouse
and restart the computer and see if it says anything about no keyboard or mouse present if so this is good now just turn off the computer and install the mouse first and reboot and see if the mouse is able to work and than do the same for the keyboard. please try these first and please let me know how this goes, there is more that we can do if needed ok please dont forget to rate this for me
best regards mike
(usn retired)
Posted on Aug 04, 2009
byteguy
  • 2229 Answers
SOURCE: Acer desktop mouse,keyboard not functioning, monitor also not wor
If there is no display on the monitor, then your computer is not sending a video signal to the monitor.
This could be caused by a bad video card or some other hardware problem. I would open the case and disconnect all the devices (hard drive, CD, etc. Leave only the CPU, memory, and video connected. You could leave the keyboard and mouse connected too.
If your computer then starts, you can start to add devices (after turning the computer off) one at a time.
If this doesn't work, then you are looking at replacing the motherboard or just the video card if that is possible.
Posted on Nov 05, 2009
Keyboard locked
If they are PS/2, power off make sure that they are not plugged into the wrong port, they will fit....but won't work that way.
If they are USB, try booting into safe mode and see if they work there
Pressing [F8] repeatedly on boot is how to get the Safe Mode options to appear, then use the Arrow-keys, (up or down,) to highlight a Safe Mode option, then press [Enter] to select it.
Tallon41
Sep 15, 2012 | eMachines ET183107 Desktop PC Intel...
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
Hello..just moved my desk top to new desk..everything is fine..but mouse won t work..while it was unplugged i cleaned keyboard..monitor with soft cloth..can u tell me why my mouse won t work
IF it's a serial mouse (meaning green round connector) it's probably not plugged in correctly. Now these are not plug and play so you need to reboot your system in order for it to work. Try that.
Jul 10, 2011 | E-Machines eMachines Desktop PC
Setting up the emachine for the first time and keyboard won't work. checked all connections.....???
Is the keyboard a USB Keyboard or PS/2... If it is a USB keyboard try plugging it into a front USB port and see if it works. If it does you might have a lose usb cable going to the back of the computer.
Jun 30, 2011 | E-Machines eMachines Desktop PC
There was a power outage. Since then the wireless mouse & keyboard would work only intermittently if at all. How to fix this?
Remove the battery of the keyboard and mouse and install new one and then press connect button from the mouse and keyboard side and the receiver side also.
Jan 14, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Hello there:
best regards mike
(usn retired)
Aug 04, 2009 | eMachines EL1210-11 PC Desktop
Emachine desktop is hanging at the intial startup screen
Most probably the keyboard has konked out. Simply try the same with a working keyboard & mouse, 'cos it seems to get stuck during POST(power on self test) due to one or more components malfunctioning. If you had removed the PS2 jacks recently, check for bent pins too.................sodeep
May 16, 2009 | E-Machines eMachines Desktop PC
Pointer locks up on the desk top after a power outage
Tried a different mouse? Maybe the power outage fried it. pc2 mouse? If it the wirring is fried or the mother board for the mouse is fried then you could purchase a USB mouse if you have an available port.  Finally download the mouse driver and reload it first.   Any more questions please ask. Thanks
http://h10025.www1.hp.com/ewfrf/wc/product?product=472140&lc=en&cc=us&dlc=en〈=en&cc=us
Jan 19, 2009 | HP Compaq Presario SR1500NX (PX786AA) PC...
Jan 17, 2009 | E-Machines eMachines Desktop PC
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
