Question about Dryers
I have a whirlpool model# le5810xpw0. it will tumble but will not heat. I just installed a new heating element and it still won't heat. any suggestions?
  • 126 Answers
Check the fuse it is about an inch long and it has two spades coming out the back. Also make sure your venting is clear from the back of the dryer to outside. If the fuse is good it could be the hi limimit t-stat. You have probably checked the circuit breaker but just in case it takes two for an electric dryer one to run one to heat. Hope that helps.
Posted on Jan 28, 2009
Duet Dryer not heating Tumbles but does not heat.
I would suspect a heating element on this model first. Unplug UNIT remove three screws at bottom of toe kick panel and remove unplug heating element check for continuity at terninals of heating element it will be the first two you will see in front
Hope this fixes your concern
Aug 13, 2010 | Whirlpool GEW9250 Electric Dryer
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
White knight tumble dryer not drying clothes. element is still hot. what is the problem?
Mar 23, 2010 | Whirlpool Dryers
Tip
on May 10, 2010 | SNK Knight 43AW Electric Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Just replaced the heating element
Apr 11, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
Nov 01, 2008 | Dryers
WHITE kNIGHT tUMBLE DRIER THAT STILL TUMBLES WITH NO HEAT
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Dryers Experts
